  • Replies 121
was good to watch.. and get out there, if only for a few short laps. Finally found out my problem in the end - dead start motor! :nyaanyaa: so got it push started at least, and got home, where it shall stay until I get a new one. damn, these things always happen when you need the car.
Hey all,
It was a great day, well the few hours I was there anyway, I only drove the morning and had to head back to work for the arvo.
I was pretty happy with my times, 1:09:04 for the clubman, and pretty consistant the whole day. Time to start spending some mony on go fast bits me thinks.
What I dickhead, I ran out of fuel and could not finish the last session on the national track, limped to the servo on vapors. I'm sure I've never used half a tank in three sessions on the clubman (which is all I had) I usually only fill it to half to keep the weight down.
Good to meet you JNewton, even if it was breifly, glad I put on a good show at turn one, bit of late braking always keeps things interesting :nyaanyaa: I toned things down in the next session, braking earlier and setting up for the corners better, got pretty much the same times as when I was hammering the brakes.
Thanks to Joe for the advice on how to fix my brake fade problems... :laugh:
Would have loved to hang around to see how that car of yours went SirSkyline, with an engine bay that shiny its gotta go fast :D So how did the clutch go?
Jmac, hope that "extreem" toe out issue is not to serious :0 So what was it like braking at the end on the main straight with that funky rear end "allignment"??
Gordon, bummer about the electrical gremlins, looking forward to seeing it out there next time.
Once again thanks to Paul and the vollies for all the work they put in.
Anyway, can't wait for the next one.
Cheers,
Pat.
Edited by JCMarshall_Law
That car my friend is a PRB Clubman...
They are a cheap self build car which is built around a 20 valve corolla motor usually...
My dad used to have one... It weighed less than 800kgs and put out 140 hp at the wheels... So yeah it was a fast little bugger...
lol I know what is , just want to know how it went
Jmac, hope that "extreem" toe out issue is not to serious 0 So what was it like braking at the end on the main straight with that funky rear end "allignment"??
Well JC, it actually didn't feel TOO bad (for those just tuning in, jmac managed to drop his left rear wheel off the kerb at turn 1 at approx 140km/h and now has about 10mm extra toe-in on that wheel which he doesn't really need). It pulled up straight, and felt worse with cold tyres. I've also scrubbed that tyre pretty badly but it'll live. Kept improving my times anyway though!!!.... I got my clubman time down from a 1:07 in May to a 1:02 today, and sprint down from 1:02 to a low 1:00 (although I was hoping I broke the 1min barrier in the last session before I left).
So since then the car's been up on the hoist..... it looks as though the control arms are ok but apparently I *might* have bent the subframe. Which is $$$ ouch grab your ankles territory. Though I'm getting Scott (Tyrezone) to look at it tomorrow - he reckons they're pretty tough and often the adjustment has just been whacked and it'll be ok. I'm not holding my breath though - every time I look at my car lately it winds up costing me $500. All for the sake of running wide in turn 1 by about 15cm...
ANYWAY I'm looking forward to the photos guys! :/ Thanks again to Paul for organising yet another great day that ran smoothly with HEAPS of track time.
Would have loved to hang around to see how that car of yours went SirSkyline, with an engine bay that shiny its gotta go fast :O So how did the clutch go?
The clutch basically slipped the entire front straight I had to back off then accelerate again and I had no traction on any of the slow corners so slicks tyres next time for sure :/
yeah.. trying to work out the exact problem now.. its either the starter or the plug around the starter is dodgy.
I'm going to try and get a set of slicks for next day too before wasting too much on extra power.. f**k those nankangs.. haha
Hey Guys, thanks to everyone who came out. It was the biggest day so far and I think it ran the smoothest. The timing gear was spot on again, so it seems the problems are solved. I will have the times out soon. I will get the big sign showing live lap data back running now as well.
When you guys are talking tyres, think Semi Slicks, not full slicks as I don't think we do enough laps to get slicks to temperature. The guys I have talked with (who have tried slicks) say they are pretty skatey while warming up.
Also I have had a lot of good feedback about the Sportsman track we tried at the end of the day. So I think we will run it again.
Paul
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
