to be honest the damage is no more than $100, but being a student thats $100 in my pocket.
i know police wont do anything, and insurance will just throw me around in circles.
the fishglue idea sounds good. but ultimately its down to the principal!!!
$100 damage huh?
I will sell you the guys address for $99.00 :(
https://www.sau.com.au/forums/topic/121481-070-fsw/page/2/#findComment-2241559
Sounds like you should sick today tonigh on thier arses!
Still sucks eug, I hope you find him, and I also hope that the police do something, if not, then sic Marks brother onto him, then only God himself will be able to save him!
https://www.sau.com.au/forums/topic/121481-070-fsw/page/2/#findComment-2242533
rofl chris you have a deal!
who's mark's brother and what does he do...
https://www.sau.com.au/forums/topic/121481-070-fsw/page/2/#findComment-2242934
Get out the old Karma and wrap it around his head, or atleast his windscreen :)
It happened to a friend of mine, all you need is the Rego and take it to the DOT fill out a stat dec form and get a JP to sign it. Then get his details take it to your insurance company and then get it fixed. Let the insurance company chase him.
https://www.sau.com.au/forums/topic/121481-070-fsw/page/2/#findComment-2243878
"then claimed that i had a particularly expensive looking car and that it was not his concern."
I would have straight up kicked his side mirror off the car... He won't chase you to fix it unless he is going to pay for the damage he did to your car.
Then would have gotten back into my car saying, "Your shitbox mirror fell off? It's not my concern..." Arnie style...
https://www.sau.com.au/forums/topic/121481-070-fsw/page/2/#findComment-2244740
Correction, should read:
Then would have gotten back into my car saying, "You never had your shitbox mirror?" Vin Diesel style...
Cause we all know Eug is Vinnie! :P
https://www.sau.com.au/forums/topic/121481-070-fsw/page/2/#findComment-2245302
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
