Hey Guys,
I just did an Oil change on my GTR and I have a q. If I put in about 300mls more than I took out, will that cause a problem? Heres the scenario:
Car was only warm when I drained it, I had idled it for a while. I have a remote oil filter + oil cooler on the car so I take a little more oil than standard. I drained it as much as I could and then plugged it back up and filled her up. Then idled again and got just under normal operating temp (maybe 2/3rds up the standard temp guage - my water temp guage had not lifted off 50 degree's) and oil pres. seemed normal. I didn't realise but the bucket thing that I used to drain into had a level on it to show how much oil was taked out and it was on 4L and I put in about 4.3L. Once warm the dipstick reported right on the H level.
Should it be ok? If not, how do I drain only 300mls? (By getting my hands dirty i bet :P )
Any info is muchly appreciated Thanks!
C
https://www.sau.com.au/forums/topic/121492-oil-change-q/
It will be fine, if it is on the H level then that is spot on.
Dont forget the oil filter will use a little oil to fill it when it is being replaced.
I actually over fill my oil by about 300mls every time- may help with oil surging I figure.
You will only get problems if you really over fill Her.
Cheers.
https://www.sau.com.au/forums/topic/121492-oil-change-q/#findComment-2239634
No problems at all Christian, all that matters is how much oil is in there now....you might have burned some of the old stuff off anyway.
Hot and cold doesn't matter so much checking oil level, but you should let it stand a minute or 2 after you've turned the motor off so the oil can drain back to the sump
https://www.sau.com.au/forums/topic/121492-oil-change-q/#findComment-2240521
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
