For those out there who cannot take part in a private track hire because your street or competition car is 10.99 or quicker, perhaps you might want to join in on a private test and tune day.
This is the same as a private track day but is limited to 12 vehicles at $375. The track is fully prepped and there are no ET limits.
Please let me know here if you are interested.
Point of clarification: it is my undertanding that only ANDRA competition cars can take part in a test and tune.
If you don't have an ANDRA licence and vehicle log book then this sort of event is not for you, instead you'd be better served by a private track day.
MrBlonde, would you know if they will let me on without a weld in molly cage running 10's? i have the license etc but i don't have the cage so i'm not allowed on street meets. i would imagine the rules would be the same but i thought i'd ask anyway.
Both street meets and test and tunes are under ANDRA rules. If your car runs quicker than 11.000 then you need a rollbar.
I discussed the options for a private test and tune track hire with John Henman at WSID recently. He mentioned the 12 cars @ $375 arrangement.
John stated that currently this is on offer for a Wednesday day. I have asked him to clarify whether or not this can be offered for a weekend day which would suit most people a little more. He is taking this to the WSID board for a decision.
There is no date yet. Once I have 12 firm starters I can solidify the arrangements.
deped=ndingon the date i may go, but if the track is not going to be prepped im not interested. best time to hold it would be after a comp meeting or tnt
Shane, the private test and tune day will be on a fully prepped track, just the same as for Top Fuellers.
Are you interested? Would be good to see you there.
definatley interested, though i have to get my gearbox out and off to south australia to find out what my problem is prior to jamboree, so at this stage i wouldnt be ready until august i would guess.
My car is getting teched friday
should be all ready in 2 weeks
so ill be in
i might have my other engine in by then
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
