to unit -> ground and power
to solenoid -> power and ground
from solenoid -> map sensor signal
at a guess
the 2 pin plug is power (ground and power) for the main unit
the 3 pin plug is solenoid and map sensor, green being map sensor signal
at a guess
So with the green wire, do i jsut tap it into the corresponding map sensor part in the ecu? And also whereabouts is the the MAP sensor in an R33?
Edited by spio
im not sure the green wire is for the map sensor, it looks like the unit has an onboard pressure sensor which you have to run a vac line into the cabin to connect to the unit.
the 2 wire plug is proly for the solenoid where as the 3 wire is for power i described above.
*edit*
the green wire might be for rpm, best bet is to email apexi usa and ask them, they are very helpful and will help you even with their legacy products.
Edited by carl h
*edit*
Yup I'll give that a shot.
Thanks for your help fellas
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
