to unit -> ground and power
to solenoid -> power and ground
from solenoid -> map sensor signal
at a guess
the 2 pin plug is power (ground and power) for the main unit
the 3 pin plug is solenoid and map sensor, green being map sensor signal
at a guess
So with the green wire, do i jsut tap it into the corresponding map sensor part in the ecu? And also whereabouts is the the MAP sensor in an R33?
Edited by spio
im not sure the green wire is for the map sensor, it looks like the unit has an onboard pressure sensor which you have to run a vac line into the cabin to connect to the unit.
the 2 wire plug is proly for the solenoid where as the 3 wire is for power i described above.
*edit*
the green wire might be for rpm, best bet is to email apexi usa and ask them, they are very helpful and will help you even with their legacy products.
Edited by carl h
*edit*
Yup I'll give that a shot.
Thanks for your help fellas
