SORRY guys i didnt make it, i had my alarm getting installed today and as always nothing gets done on time.
i was shattered and i still have to wait untill tuesday for the alarm.
Is it bad to use my 19s???? I thought the bigger the wheel the more faster you go?
oh yeah i also have a apexi pod filter, if that helps.
Edited by Tough R34
If that is a serious statement i better set the record straight.
The bigger the wheel, the heavier it is, also the more force/power needed to get it moving. Due to the small profile there is no give in the tyre, thus will break traction more easily. 19's are just for show, they are bad for everything else. I am not bagging you as i also have 19's on my Skyline.
The Apexi pod will not improve anything until you are making over 230rwkw, that's where the std air box becomes a restriction. In fact your pod is probably loosing you some performance, as you probably have it open in the engine bay, free to suck in all that hot air. A pod always should to be enclosed in a custom box with a big cold air feed, from the front bar.
Hope to see ya next time at Calder
emsta: Calder Park Rwy, is just off the Calder Fwy, near Taylors Lakes, Hillside, etc., just before Sunbury.
On a Friday night, it is $20 to spectate and $55 to enter your car. To compete you will need to where long paint, long sleeved top, runners/shoes, and a Helmet (which can be hired).
NICE BURNOUT
At first i was like "WTF is he talkin about" Then i looked at my post :)
PS: Thanks ;) Compliments of DECA skid pan.
If you are going to buy rims, you'd be better off buying a set of 17 x 9 for the rear. I have a set of 4, 17in rims for sale (mis-matched pairs, great for drag, drift and drag ;) ), rear are new and only been used twice, fronts are s/h and in good condition, $300 for all 4, no tyres :P
Had to upgrade due to my latest Brembo brake upgrade :D.
SIF 17's are best
smaller the better, more sidewall, more flex, more traction
i has R33 wheels if you want... provided Ronin aint gonna borrow em, crap rubber $150... but yeah... Ronin has dibs if he needs to use them to move his car around :)
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
