Hey guys just after some feedback.
Currently at the stage of buying some injectors for my S2 r33, Current list of mods
HKS FMIS
HKS POD
3" turbo back zust
Walbro fuel pump
Garrett turbo slightly bigger then a T28
Duel Stage boost controller
SAFC 2.
All i have on the car at the moment is the zust, FMIS, pod the rest are to be install.
With some decent injectors could I expect this kind of power or this won’t happen till I buy a Power PC which I’m trying to avoid because of the $$. (also trying to save for a house)
Was thinking NIZMO 750CC????
Thanks
Edited by the97skyline
https://www.sau.com.au/forums/topic/121589-need-help-picking-injectors/
you havent listed a power target so we cant help.
for any injector changing you need aftermarket ecu, powerfc will do fine.
without knowing any more power requirements
s15 sr20 jdm manual 480cc injectors
nismo 550cc rb25 injectors
both are straight fit and dial in (with the right ECU)
How do you mean "dial in with the right ECU"?
Ive got an auto, and with the higherflowing turbo Im going to get (eventually) Im guessing Im going to need injectors - I use a SAFC-2 and an SITC as my piggyback controllers.
greddy emanger ulimate with injector hardness = best option for an auto skyline
' date='9 Jun 2006, 01:28 PM' post='2242142']
NUP - no way would that be going on my car, Ive heard nothing but BAD reports about these.
The safc and sitc stay, no discussion...... whats the point of having them installed, tuned and retuned, and then not using them when I go for a larger turbo?
at the end of the day, simply Id like to know: can the safc "utilise" larger than stock injectors (either hiflowed injectors or new Nismo items)?
so my comment was target directly at you, just saying in general that the greddy is a extremmely good ecu (of course that is if the tuner is good at tuning the ecu)
im not 100% sure if u can run aftermarket ecu with the safc and sitc but you can just buy another addon like you have i know hks,greddy and pivot make one for running aftermarket injectors
' date='9 Jun 2006, 01:41 PM' post='2242186']
'Nah no worries Michael, thanks for the info (sorry for hijack of thread, after same info as you 97'Line), just that Ive heard too much bad news about the emanage, plus Ive got 2 piggybacks already and dont have much left in my modifying budget allowance. doh (ie to uninstall, sell, buy emanage and harness, then finding an adelaide tuner = too hard & expensive basket)
I'll research into the add-ons that you've mentioned. Cheers
Im after 200-210awkw (4wd auto); have everything ready barring the larger turbo. Not sure if I'll require the bigbadgranddaddy injectors.... currently at around 70% duty using a Nismo adj.FPR.
Good luck with your injecotr choice 97skyline!
Brendan
Edited by Tangles
For small injector upgrades the SAFC’s seem to work OK, so 370 cc’s to 440-480 cc’s would be OK. Once you get over that you are past the same limit for standard internals anyway. So you might as well change the inlet to a Greddy and go for top feed injectors, where there is a much larger range at lower prices.
An adjustable fuel pressure regulator (Nismo bolt on, ~$150 from Nengun) will also help the SAFC tuning as you can juggle the fuel pressure to get the target A/F ratios.
:( cheers :)
:) cheers :D
:D cheers :D Gary!
(and thanks to michael for the info on fuelinjectors piggybacks - never knew they existed)
awesome info...... hmm, Im guessing I'll hiflow the standard injectors then, to 450cc's or thereabouts.
What about you 97skyline? which way are you going to go?
http://www.hksusa.com/products/?id=638&rsku=4361
wow, not cheap
HKS AIC III Si (Additional Injector Controller) - $800 usd LOL
(edit: used gear can be found on ebay LOL)
Edited by Tangles
Yeah sorry i also do have a fuel pressure regulator. So you think that anything over say 470cc with my mods really wont help much as i haven’t done internals. I have a mate with a 200 very similar mods to my car bar a new turbo and he also has a Power FC, got recommended to get at least 555CC, i though skylines being a bigger motor would need bigger ones. Haven't really thought about high flowing the standard ones.
A place in Melbourne do them - APS by memory? anyone wish to confirm?
Also - to Sydneykid...
Gary, youve got a very nice Stagea; once you add your larger turbocharger (GCG hiflow Im sure), tuned with your SAFC and SITC, with your full exhaust and R34 GTT Intercooler - do you expect to have to use larger injectors yourself???
I understand you were aiming for around 200awkw as well.
to the 97skyline - you can get injector controllers off ebay, most look used and are a JuMbLe of wires & leads etc, not tooooo expensive....... but fitting and tuning might be.
Why would i need an injector controller though???? is that becuase i don't have a Power FC???
What are people using these days???????? or is everybody just high flowing them
I doubt itd be worthwhile (an injector controller - just posting my research thats all).
To work within Garys parameters that he described, go either the SR20 JDM 480cc, or highflow the standard injectors. Most people prefer to steer clear of highflowing the injectors............. Im not too worried tho. Itd be easier (and cheaper) to highflow to ~450cc then finding 6 x JDM S15 injectors.
750cc are good for 400kw, i use 580cc and make 300kw. bigger injectors are harder to control at idle and on cruise.
HKS FMIS
HKS POD
3" turbo back zust
Walbro fuel pump
SAFC 2.
Thanks
HKS FMIS
HKS POD
3" turbo back zust
Walbro fuel pump
SAFC 2.
Thanks
The stock injectors supply more than the stock turbo can pump... if its only "slightly" bigger i doubt your on the limit.
Nismo dont make a 750, they are 740cc for the RB25 rail.
Or Nismo 550 or Nismo 555... one of the two for the RB25 again...
If you really need injectors, then the 55x would be my pick with a PowerFC
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
