Hey guys just after some feedback.
Currently at the stage of buying some injectors for my S2 r33, Current list of mods
HKS FMIS
HKS POD
3" turbo back zust
Walbro fuel pump
Garrett turbo slightly bigger then a T28
Duel Stage boost controller
SAFC 2.
All i have on the car at the moment is the zust, FMIS, pod the rest are to be install.
With some decent injectors could I expect this kind of power or this won’t happen till I buy a Power PC which I’m trying to avoid because of the $$. (also trying to save for a house)
Was thinking NIZMO 750CC????
Thanks
Edited by the97skyline
https://www.sau.com.au/forums/topic/121589-need-help-picking-injectors/
you havent listed a power target so we cant help.
for any injector changing you need aftermarket ecu, powerfc will do fine.
without knowing any more power requirements
s15 sr20 jdm manual 480cc injectors
nismo 550cc rb25 injectors
both are straight fit and dial in (with the right ECU)
How do you mean "dial in with the right ECU"?
Ive got an auto, and with the higherflowing turbo Im going to get (eventually) Im guessing Im going to need injectors - I use a SAFC-2 and an SITC as my piggyback controllers.
greddy emanger ulimate with injector hardness = best option for an auto skyline
' date='9 Jun 2006, 01:28 PM' post='2242142']
NUP - no way would that be going on my car, Ive heard nothing but BAD reports about these.
The safc and sitc stay, no discussion...... whats the point of having them installed, tuned and retuned, and then not using them when I go for a larger turbo?
at the end of the day, simply Id like to know: can the safc "utilise" larger than stock injectors (either hiflowed injectors or new Nismo items)?
so my comment was target directly at you, just saying in general that the greddy is a extremmely good ecu (of course that is if the tuner is good at tuning the ecu)
im not 100% sure if u can run aftermarket ecu with the safc and sitc but you can just buy another addon like you have i know hks,greddy and pivot make one for running aftermarket injectors
' date='9 Jun 2006, 01:41 PM' post='2242186']
'Nah no worries Michael, thanks for the info (sorry for hijack of thread, after same info as you 97'Line), just that Ive heard too much bad news about the emanage, plus Ive got 2 piggybacks already and dont have much left in my modifying budget allowance. doh (ie to uninstall, sell, buy emanage and harness, then finding an adelaide tuner = too hard & expensive basket)
I'll research into the add-ons that you've mentioned. Cheers
Im after 200-210awkw (4wd auto); have everything ready barring the larger turbo. Not sure if I'll require the bigbadgranddaddy injectors.... currently at around 70% duty using a Nismo adj.FPR.
Good luck with your injecotr choice 97skyline!
Brendan
Edited by Tangles
For small injector upgrades the SAFC’s seem to work OK, so 370 cc’s to 440-480 cc’s would be OK. Once you get over that you are past the same limit for standard internals anyway. So you might as well change the inlet to a Greddy and go for top feed injectors, where there is a much larger range at lower prices.
An adjustable fuel pressure regulator (Nismo bolt on, ~$150 from Nengun) will also help the SAFC tuning as you can juggle the fuel pressure to get the target A/F ratios.
:( cheers :)
:) cheers :D
:D cheers :D Gary!
(and thanks to michael for the info on fuelinjectors piggybacks - never knew they existed)
awesome info...... hmm, Im guessing I'll hiflow the standard injectors then, to 450cc's or thereabouts.
What about you 97skyline? which way are you going to go?
http://www.hksusa.com/products/?id=638&rsku=4361
wow, not cheap
HKS AIC III Si (Additional Injector Controller) - $800 usd LOL
(edit: used gear can be found on ebay LOL)
Edited by Tangles
Yeah sorry i also do have a fuel pressure regulator. So you think that anything over say 470cc with my mods really wont help much as i haven’t done internals. I have a mate with a 200 very similar mods to my car bar a new turbo and he also has a Power FC, got recommended to get at least 555CC, i though skylines being a bigger motor would need bigger ones. Haven't really thought about high flowing the standard ones.
A place in Melbourne do them - APS by memory? anyone wish to confirm?
Also - to Sydneykid...
Gary, youve got a very nice Stagea; once you add your larger turbocharger (GCG hiflow Im sure), tuned with your SAFC and SITC, with your full exhaust and R34 GTT Intercooler - do you expect to have to use larger injectors yourself???
I understand you were aiming for around 200awkw as well.
to the 97skyline - you can get injector controllers off ebay, most look used and are a JuMbLe of wires & leads etc, not tooooo expensive....... but fitting and tuning might be.
Why would i need an injector controller though???? is that becuase i don't have a Power FC???
What are people using these days???????? or is everybody just high flowing them
I doubt itd be worthwhile (an injector controller - just posting my research thats all).
To work within Garys parameters that he described, go either the SR20 JDM 480cc, or highflow the standard injectors. Most people prefer to steer clear of highflowing the injectors............. Im not too worried tho. Itd be easier (and cheaper) to highflow to ~450cc then finding 6 x JDM S15 injectors.
750cc are good for 400kw, i use 580cc and make 300kw. bigger injectors are harder to control at idle and on cruise.
HKS FMIS
HKS POD
3" turbo back zust
Walbro fuel pump
SAFC 2.
Thanks
HKS FMIS
HKS POD
3" turbo back zust
Walbro fuel pump
SAFC 2.
Thanks
The stock injectors supply more than the stock turbo can pump... if its only "slightly" bigger i doubt your on the limit.
Nismo dont make a 750, they are 740cc for the RB25 rail.
Or Nismo 550 or Nismo 555... one of the two for the RB25 again...
If you really need injectors, then the 55x would be my pick with a PowerFC
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
