For sale: 1995 Nissan R33 GTS-T
Asking Price: $14,000 ono
Killometer's: 117,***
Manual or Automatic transmission: Manual
Engine Type: RB25DET in line 6 turbo
Modifications: 3.5' Cat back with 5 inch cannon, Greedy turbo timer, Hks Mushroom filter, DBA 4000 series slotted disks, Race brakes Rb74 Pads Front, Mu's pad as extra (for back currently standard nissan on back) blistein suspension. bosch 040 fuel pump, cusco strut bar, black widow alarm with immobilser (2x controls), clarion head unit with cd/mp3. Potenza Re01 tyres (front) 80% tread, Brand new sumitomo tyres (rear) approx 90% and also a series 2 spoiler.
Running standard boost pulled 153.7RWKW @ Dr Drift with my old exhaust which was a 3 inch and a filter, was leaning out due to old fuel pump shitting it self thus being replaced with in tank bosch 040 pump
Currently running 10psi
Reason for sale:have to pay for uni
Complianced: Yes
Road Worth Certificate: Yes
Registration: Until November 06
Contact detail's: Tahir Mevlut - 0421852890
Edited by SXDCTR
https://www.sau.com.au/forums/topic/121629-1995-r33-gts-t-series-1/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
