Item: CLARION TVX6651 IN DASH TV
Item Condition: USED, GOOD CONDITION
Reason for Selling: Not Needed
Price and Payment Conditions: $500 cash, pick up only
Extra Info: 6.5" COLOUR LCD TV - PAL - 280,800 Pixels
TFT Active-Matrix 6.5-inch LCD monitor with high resolution and semi-motorised opening/closing
Built-in TV Tuner
Screen Size Select
Built-in FM Modulator (Wide/Full wide/Cinema/Normal)
Front AV input(35mm mini jack):1
Rear Video input (RCA):1
Rear CCD/Video input(DIN):1*
1 Video Output (RCA)
motorized push button
comes woth remote control
https://www.sau.com.au/forums/topic/121645-clarion-tvx6651/
i got one of these Tv;s myself, they are awesome, I paid about $1800 for mine new with the arials. IF it were mine i wouldnt let it go for anything under $500. Thats why i didnt sell cause i didnt get a decent offer. $300 your dreaming pal.
https://www.sau.com.au/forums/topic/121645-clarion-tvx6651/#findComment-2275425
this guy knows wat hes talking about reason for selling is im selling my car and i pulled out everything and put stock cd player back in and took my tv out and the dvd player comes with a remote and there is no box sorry if u want it buy it i jus have no need for it
https://www.sau.com.au/forums/topic/121645-clarion-tvx6651/#findComment-2275670
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
