Hey there, just got a car I'm looking at buying inspected and although there were a fair few other things wrong with it, the one i'm majorly concerned with is one listed as requiring early attention and described as. Front wheels, one side is 20mm further forward than other. It says that it will require specialist attention to acertain the reason for it. I rang a few places and they all seemed to think the most likely reason for it would have been an accident at some stage. Just wondering if anyone has had any experience with a similar problem or knows how likely it is that this could be a serious problem? I don't want to buy the car only to find out that it has been crashed and has some serious chasis damage.
Thanks.
https://www.sau.com.au/forums/topic/121649-wheel-mis-alignment/
Thanks.
It could be something as simple asa worn radius rod bush, or something as bad as a bent chassis rail. Any decent suspension shop should be able to do a complete wheel alignment check and point you in the right direction.
:) Cheers :P
I work for a joint what does Wheels Tyres and Alignments, and the front wheel on the left side of the car should be set forward a little more than the right side, cos of the "australian road conditions" we run a higher road camber here, so the left wheel is set forward a little bit to allow for the car to drive straight on the road.
Hmm, if it's chasis damage (worst case scenario) then it could very well be irrepairable right? I've never heard of one wheel being set forward a little more than the other... would it be set forward as much as 20mm?
What would be my best course of action to get the problem diagnosed? Someone mentioned maybe take it to a wreckers and they have a machine there to check the body alignment using the datum points etc.
That would be a panel beater, make sure they have the data for a Skyline
Yep more caster on the LHS front to stop the drift into the gutter caused by the camber of the round.
But 20 mm is a bit too much
:P cheers :mad:
Hey guys,
This is actually my skyline he is talking about.
Here are two wheel alignment read-outs one (bobjane) before the white line gear was put in and one (wilkinsons) after the white line one was put in.
They were done less then a month apart.
The bob jane shows castor left +6'33" right +6'48"
The wilkinsons shows castor left +7'38" right +5'38"
Isnt this proof that all that has happened is that wilkinsons has set the whiteline adjustable caster up for aussie roads? also wilkinsons never mentioned any problems what so ever so I really think eveyrthings ok.
I will be ringing on monday to confirm, as this sale is hinging on this car being straight or not.
EDIT: the bobjane readout was from one of those crappy ribbon printers so it didnt scan well but you guys can make out the numbers yeah? its much easier to read from the original.
Edited by noise
If it is the castor setting an easy check would be to climb under and measure from the centre of the front castor rod bolt to the first of the 2 on the lower control arm.
If one's shorter than the other then i'd say that it's all in the adjustment.
I just got down and had a look, you can see more yellow on the right one I think it was and less on the left. Considering the angle they are sitting on is how you adjust them and one is sitting out further I would say the mystery has been solved, will confirm with the suspension guys on Monday.
RAC is getting a letter of complaint next week for sending out a mechanic who wrote a false and misleading statements about my car which resulted in the sale of the car being stalled and possibly called off.
Not happy :ermm:
Edited by noise
Dude if there was a mojor problem Wilkinson would have told you. I really doubt there is an issue. Sounds like alignment settings to me. The RAC job is to pick faults. They are normally mechanics, not alignment experts so i would take on board the oil leaks etc they point out, but probably not the alignment.
Regards
R Dirty 3
Sorry you mentioned bob jane... I zoned out after that..
Yes 20 mm is a bit much for castor, but was the RAC telling you the truth. got the same problem in Adelaide with RAA car inspectors, tell ya lies and dont know what they are on about.
Bob Janes here in Adelaide are prolly the worst people in the world to let near your car. I dont know what they are like anywhere else in the country, but here in Adelaide, they will tell you that your car needs half the front end rebuilt just to get the work... and here in adelaide a few of my mates own the old classic holdens and chevs, and every bob janes they have gone to, dont know how to wheel align there cars, so if you need your car to be wheel aligned to specs or to match Aust road conditions, I would honestly look for someone in a small local business, cos they have to do it right, else no one would goback to them.
Just my 2 cents worth on wheel alignments from bob janes.
Sorry if it seems like i am havinga cry over businesses, but i just offer my advice.
WARNING to anyone buying or selling your car, make sure you tell the mechanic to ignore anything after market on the car otherwise they will list aftermarket parts as problems that need fixing.
exhaust, pedals, airpod etc.
The mechanic could have just looked under the wheel arch and seen the BRIGHT YELLOW adjustable caster rod thing and measured it to make sure it was all ok.
Dodgy as f#*$
Edited by noise
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
