Hey there, just got a car I'm looking at buying inspected and although there were a fair few other things wrong with it, the one i'm majorly concerned with is one listed as requiring early attention and described as. Front wheels, one side is 20mm further forward than other. It says that it will require specialist attention to acertain the reason for it. I rang a few places and they all seemed to think the most likely reason for it would have been an accident at some stage. Just wondering if anyone has had any experience with a similar problem or knows how likely it is that this could be a serious problem? I don't want to buy the car only to find out that it has been crashed and has some serious chasis damage.
Thanks.
https://www.sau.com.au/forums/topic/121649-wheel-mis-alignment/
Thanks.
It could be something as simple asa worn radius rod bush, or something as bad as a bent chassis rail. Any decent suspension shop should be able to do a complete wheel alignment check and point you in the right direction.
:) Cheers :P
I work for a joint what does Wheels Tyres and Alignments, and the front wheel on the left side of the car should be set forward a little more than the right side, cos of the "australian road conditions" we run a higher road camber here, so the left wheel is set forward a little bit to allow for the car to drive straight on the road.
Hmm, if it's chasis damage (worst case scenario) then it could very well be irrepairable right? I've never heard of one wheel being set forward a little more than the other... would it be set forward as much as 20mm?
What would be my best course of action to get the problem diagnosed? Someone mentioned maybe take it to a wreckers and they have a machine there to check the body alignment using the datum points etc.
That would be a panel beater, make sure they have the data for a Skyline
Yep more caster on the LHS front to stop the drift into the gutter caused by the camber of the round.
But 20 mm is a bit too much
:P cheers :mad:
Hey guys,
This is actually my skyline he is talking about.
Here are two wheel alignment read-outs one (bobjane) before the white line gear was put in and one (wilkinsons) after the white line one was put in.
They were done less then a month apart.
The bob jane shows castor left +6'33" right +6'48"
The wilkinsons shows castor left +7'38" right +5'38"
Isnt this proof that all that has happened is that wilkinsons has set the whiteline adjustable caster up for aussie roads? also wilkinsons never mentioned any problems what so ever so I really think eveyrthings ok.
I will be ringing on monday to confirm, as this sale is hinging on this car being straight or not.
EDIT: the bobjane readout was from one of those crappy ribbon printers so it didnt scan well but you guys can make out the numbers yeah? its much easier to read from the original.
Edited by noise
If it is the castor setting an easy check would be to climb under and measure from the centre of the front castor rod bolt to the first of the 2 on the lower control arm.
If one's shorter than the other then i'd say that it's all in the adjustment.
I just got down and had a look, you can see more yellow on the right one I think it was and less on the left. Considering the angle they are sitting on is how you adjust them and one is sitting out further I would say the mystery has been solved, will confirm with the suspension guys on Monday.
RAC is getting a letter of complaint next week for sending out a mechanic who wrote a false and misleading statements about my car which resulted in the sale of the car being stalled and possibly called off.
Not happy :ermm:
Edited by noise
Dude if there was a mojor problem Wilkinson would have told you. I really doubt there is an issue. Sounds like alignment settings to me. The RAC job is to pick faults. They are normally mechanics, not alignment experts so i would take on board the oil leaks etc they point out, but probably not the alignment.
Regards
R Dirty 3
Sorry you mentioned bob jane... I zoned out after that..
Yes 20 mm is a bit much for castor, but was the RAC telling you the truth. got the same problem in Adelaide with RAA car inspectors, tell ya lies and dont know what they are on about.
Bob Janes here in Adelaide are prolly the worst people in the world to let near your car. I dont know what they are like anywhere else in the country, but here in Adelaide, they will tell you that your car needs half the front end rebuilt just to get the work... and here in adelaide a few of my mates own the old classic holdens and chevs, and every bob janes they have gone to, dont know how to wheel align there cars, so if you need your car to be wheel aligned to specs or to match Aust road conditions, I would honestly look for someone in a small local business, cos they have to do it right, else no one would goback to them.
Just my 2 cents worth on wheel alignments from bob janes.
Sorry if it seems like i am havinga cry over businesses, but i just offer my advice.
WARNING to anyone buying or selling your car, make sure you tell the mechanic to ignore anything after market on the car otherwise they will list aftermarket parts as problems that need fixing.
exhaust, pedals, airpod etc.
The mechanic could have just looked under the wheel arch and seen the BRIGHT YELLOW adjustable caster rod thing and measured it to make sure it was all ok.
Dodgy as f#*$
Edited by noise
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
