I have found that a standard 3 guage DIN panel would not fir into a SII Stagea. A little find of fiddling and I have managed to get 3 guages mounted above my stereo rather neatly.
Thats what I want. But wot fiddle?
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2244015
I'll be doing that soon, too! I might move the air-con controls to the middle though, the guages up top, and put the stereo in the bottom slot.
Did you buy a DIN-slot holder for the guages, or did you make one up?
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2244102
66yostagea - Because the DIN guage would not fit I had to make up my own panel.
GoldZilla - homemade using 2 thin pieces of MDF, cut to different sizes and glued. Then had a local signwriter profile cut the holes accurately (very little room for error). Cost me 1 grazed knuckle (left hand) and $15 for profile cut.
The smaller back section is a 'snug' fit into the metal frame and all is held in place by the front plastic facia - quite solid.
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2244232
Was it only the SII 'S' that had the three gauges in as standard? ie the ones mine has? Or was it somthing introduced in all the later SII's??
Ian
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2244692
Luv your work. Do u feel like getting a few more made up being you know the dimensions?.
Sorry team, I would love to assist but I am down a store manager and end of financial year is nearly upon us all. The Stagea will be going onto the back burner for at least 2 months.
Know that I have the unit fitted I am inclined to lean towards a black/dark gray perspex. If I get one of these made up in the future and all is good I shall see if a small run can be done.
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2244998
Ian
Yep, as far as I am aware only the series II "S" type manual comes with those 3 centre guages.... also has some different front seats too :P
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2245598
What size are the gauges you put in there? 60mm...
Id be suprised if you could fit 3 defi gauges in a small holder like though as they are 60mm gauges which is quite big
The Defi guages I'm aiming to get are the 52mm ones, and if I manage to get the panel right when I make it, I might make a few of them to sell onwards.
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2246079
Interestingly my boost guage is reading 8.5psi. I thought max was 7psi standard. I can only assume that a split dump pipe and full 3" exhaust has allowed things to breath a little better. Either that or my boost guage is skewed. Apart fromt the above mentioned exhaust, the car is standard.
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2247203
  • 6 months later...
marc2, I know we are going back 6 months but did you have any pics of gauges and front panel before fitting? Has anybody nutted out how to fit the R32 GTR 3 din gauges? Can I modify the standard front panel mounts or just make up new panel? Has anybody seen S2 Stagea manual 3 din gauges 4sale?
https://www.sau.com.au/forums/topic/121652-idg/#findComment-2772344
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
