yeh ok so ive read many people saying its good and that it should be done if the car has just been imported so it can learn our driving conditions, but ive heard many say its dumb and if anything itll mess the car up. I got quite a few problems with my car at the moment and was hoping doing this might help me with them. Mainly fuel related (leaning out, no pressure, no flow) but also boost related (got fmic and boost @ 12) as well as possibly spark related (coil packs). So anyways i figure it cant hurt to try... correct? orr incorrect ?
I did search for "ecu resetting" under modifications and maintenance but got 4 unhelpful results, so if any 1 has a spare 2 seconds itd be muchly appreciated.. i did once find a seperate webpage talking about it and other mods for skylines that can be useful, which i got off this forum, but ive lost it.. to reset i think it was something like take off battery, hold down brakes for a minute or smtn
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/121655-ecu-resetting-hehehehehe/
its a wives tail, you wont gain anything i dont reckon
1) turn car off
2) undo ground wire for battery
3) pump brake pedal, all power should go off
4) reconnect
5) fang
Paul
do you think that the PFC has an "auto learn" function as well. I'm also a little sceptical of this.
the powerfc has a self idle learn procedure which is executed when a user does a DATA INIT or when the unit is shipped as new from the factory. the self idle learn simply learns the car's optimum idle point by what i suspect is looking at the sensors and picking a varyation of paramters to get a constant idle that varies with say 5% and doesnt hunt up and down.
there is no self tune feature, self adjustment or anything else.
it is purely so the FC can out of the box run on almost any car setup and idle properly. nothing worse than shonky idle out of the box.
other ecu's that run a self tune use a wideband sensor and basically dial in or out AFR"s on demand based on what target or ideal AFR you give it. it reads what the wideband sensor says and decides if it needs more or less fuel. it can only be done with a wideband sensor
Dude do you said it yourself that there was no fuel flow so how the f**k is a ECU reset going to fix that? I've got a spun big end I wonder if an ECU reset will fix that??????
And Paul as for self learning the PFC doesn't have fuel trim cells so each time it goes through a certain point that may be above or below stoich then it has to trim the fuel accordingly it will not learn rich and learn areas of the map and compensate for it.
Also the self learn idle is just a control loop of the IAC motor nothing else.
Edited by rob82
relax relax relax relaxavou. Forgot i had adjusted my boost down about 2 psi just before resetting the ecu. Would help with leaning out a high rpm, dunno about the stuttering at 3k but that wsa almost gone. For interest sake, the ecu cant change fuel flows or ne thin? Like with a carby u can adjust it to run richer or leaner, a ecu cant do that?
worth at least 25 rwkw when i did mine :laughing-smiley-014:
i've never noticed any difference with a reset. no wait, i have...usually pissed off because battery has been disconnected and i need to reset the radio.
The ECU reset does not always improve things from when they come over from Japan as 9/10 they change the battery to start the bastard when it comes off the boat and it has already lost it's memory from the self learn previously.
As for the "re-connect battery and fang", this is totally incorrect, you don't fang it around once it has been reset, you must drive it in all types of conditions. Cruising and power on. The factory computer DOES have a self learn procedure and it DOES improve driveability once it has re-learnt after a certain time.
You have other issues though. Have you changed your fuel filter lately, checked spark plugs? The fuel pumps are nearly always screwed so that could be your problem. Coil packs fail all the time. Don't expect the reset to make things better if there is a problem because the ECU will only learn around them. Then you will have problems once they are fixed.
ECU resets now fix:
1. Flat tyres
2. Flat Batteries
3. Broken head gaskets
4. Spun big ends
5. Crack or destroyed ring lands and
6. Dying fuel pumps
You know thats handy to know. I got a flat tyre tonite, got a screw in it. But will I still need to pump up the tyre, or will giving it a fang around fix that problem also?
Im running with Dan on this one tho. Fix the problem stuff, then reset.
all i know is a ecu reset, clears stored errors. e.g if you afm was stuffed and the ecu showed the code for a stuffed afm, a reset would clear this code (just untill the ecu sees the stuffed afm again)
rumour has it, depending on the problem a ecu can into "limp home mode" which makes it run very rich, just to get you home or some crap like that......
steve
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
