Me too , I've got 2c to spend .
Lets just say you have your engine running on boost and for whatever reason you leap off the go pedal . Inlet manifold and exhaust flow drops like a brick and for a very short time the turbos innertia will prevent it from stopping dead . What you now have is an area of higher pressure between the compressor outlet and the throttle plate/s and nowhere for the compressed volume to vent other than back towards the compressor . Rotary compressors are designed to be efficient in one airflow direction so they react badly when you get the reversal happening . Cavitation/hissys call it what you like but the compressor is definately in not happy Jan mode .
Like some others I got to see the the technology change (84-96 era) going from a std engined Skyline DR30RS (FJ20ET) to a similar state R33 GTS25T . Like the RB30ET the FJ had no throttle closed recirculation valve (I'll call it TCRV) and it did make the flutter noise even with its std boost pressure of ~ 7 PSI . The thing I really did notice was the DR30 felt a little strange going from a loaded state ie 1/2 throttle to ALMOST closed , the residual pressure in the system gave a sort of delay to the engine unloading or backing off - unless the throttle was closed . The R33 does none of this and is quite responsive to rapid on/off throttle inputs . Now the load sensing devise is different in these cars the older being gate type AFM and the later Hotwire MAF . Unlike a MAP sensor these both react to mass air flow so are obviously upstream devices . If anything the MAP sensor is the one kept mostly in the dark because it can't see whats happening on the outside of the throttle plates so pressure out here means nothing to it .
When you have a TCRV it becomes the "compressed volumes" escape route but I'd say its critical how its fed back into the system upstream of the compressor housing . A MAF sensor can only react to airflow throught it - so if it gets a sudden pressure rise on the engine side flow through it could slow or even pause . No airflow means no load signal so the ECU probably thinks fuel off and siesta time . I think it would pay to look at how Nissan set out their TCRV systems so that you can copy the positive aspects and avoid the stalling or fuel off antics .
I think the bottom line is later RB powered cars use them so until they create a problem leave it as it is . Even the std one does the hiss thing with non std filters ie pods fitted . If I was going to do anything to mine I'd fit the twinned RB26 ones and call it a day , I believe it comes back to the airflow for power instead of boost for power because extra pressure brings extra dramas IMO .
Almost forgot , later era cars are using higher boost pressure than FJ20ET/RB30ET cars did so the TCRV would have more potential to correct drivability glitches with rapid throttle inputs .
2c gone cheers A .
Nope no regrets . In a car of that weight strut front/semi trailing arm IRS and can't steer straight link steering is a real downer . Just about every aspect of R30's paints you into a corner and FJ20's are very crude electrically speaking . You learn to hate two twin row timing chains and the dizzy type CAS . We won't go into 4 stud hubs and disks that bolt behind them will we ...
I didn't like to hear it at the time but someone here made it clear that the overall technology jump from R30/31 to R32 and later was "a quantam leap" . Very good advice .
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
