Hey all just a quick question. I am building up a VN SS show/circuit car and have decieded on using the 4 piston calipers as found on the Skyline range. My question, is there any difference in the calipers between the models or was the same caliper used? Did the new ones accept a larger disc, etc. Also is there a difference with say the gts-t and gt-r, etc
I will be using HSV 343x32 rotors with these.
Thankx Dave
Edited by AirStrike
i c..
32gtr is the same as 33gtst. 298 by 32mm
33/34gtr uses brembo calipers on a 328 by 32mm disc.
32 gtst uses pidly 280mm by 28mm disc.
z32 uses 2800 by 32mm discs.
the brembos use a diferant pad.
the non brembos use a db1170 pad. (common as)
id use the brembos. or try and find some porche brembos. (big reds) as the pads are sutabe for a large discs.
but ferrari f40 calipers are perfect for 343mm disc. (slighty shallower pad from the big reds.)
my advise is ebay to buy them. just do s asearch for "brembo brake caliper"
i c..
Cheers Mate. Dont want to go too expensive on the brakes I think the 4 spots will surfice. So with the R32gtr and R33gtst they use the same rotor, but is the caliper the same?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
I was thinking something like this?
Also will the calipers I listed above fit on a 343mm rotor? I know I can fit them on a 330mm with out any problems.........
Hell anything is an improvment over stock! 289x23mm with a single piston caliper!
Cheers Dave
Edited by AirStrike
i c..
Here are the correct sizes:
R32 GTST
Front rotors (diam x thk) - 280×30
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296×32
R33 GTST
Front rotors (diam x thk) - 296×30 Different caliper to R32 GTR but same disc diameter.
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Front rotors (diam x thk) - 324×30
R34 GTT
Front rotors (diam x thk) - 310x30
The calipers that suit larger diameter discs have longer mounting legs to space the caliper out further.
When using R32 GTR calipers on 330mm discs I filed out the inside radius a mm or 2, i presume R33 is the same. R34 GTT mightn't need and mods.
R32 GTST
R33 GTST
R34 GTT
Hmmmmmm..............Any one know how to differenciate the calipers from each other?
Dave
  • 1 month later...
I have found this thread useful with thinking about a brake upgrade. It would be great as a sticky and would answer a few questions. Just knowing the stats of rotor diameter/thickness and the calipers.
Who makes these sticky's?? It would be great to compile this info into one thread.
Russell
I have the specs of a lot of Nissans in a spreadsheet, basically
R32 GTST
Master Cylinder diam (mm) - 25.4
Front Caliper Piston(diam x qty) - 40.4 ×4
Rear Caliper Piston(diam x qty) - 38.18×2
Rear Rotors (diam x thk) - 297×18
R33 GTST
Master Cylinder diam (mm) - 23.8
Now the interesting bit...
Master Cylinder diam (mm) - 26.9
Front Caliper Piston(diam x qty) - (44+38)×2 ... leading pistons smaller then trailing
Rear Caliper Piston(diam x qty) - 40×2
Rear Rotors (diam x thk) - 300×22
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end a made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
    • As someone who has pineapples, and horrible axle tramp... should I change these to collars? Is that what you're saying here? Why did you choose these instead of getting pineapples where you said you had good experiences of? I'd love to even attempt to get rid of axle tramp, I either get complete bogginess or absolute insane wheelspin, anything even remotely in between results in filling-removal axle tramp, to the point where launching the car is just not something I do.
    • Lucky for that, because putting ethanol in fuel only lowers the bulk cost of fuel if it's in 91 Add it to 98, 85% of it even and it quintuples in price. Strange physics. f**k you United, Gouging c***ts.
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
