Hey all just a quick question. I am building up a VN SS show/circuit car and have decieded on using the 4 piston calipers as found on the Skyline range. My question, is there any difference in the calipers between the models or was the same caliper used? Did the new ones accept a larger disc, etc. Also is there a difference with say the gts-t and gt-r, etc
I will be using HSV 343x32 rotors with these.
Thankx Dave
Edited by AirStrike
i c..
32gtr is the same as 33gtst. 298 by 32mm
33/34gtr uses brembo calipers on a 328 by 32mm disc.
32 gtst uses pidly 280mm by 28mm disc.
z32 uses 2800 by 32mm discs.
the brembos use a diferant pad.
the non brembos use a db1170 pad. (common as)
id use the brembos. or try and find some porche brembos. (big reds) as the pads are sutabe for a large discs.
but ferrari f40 calipers are perfect for 343mm disc. (slighty shallower pad from the big reds.)
my advise is ebay to buy them. just do s asearch for "brembo brake caliper"
i c..
Cheers Mate. Dont want to go too expensive on the brakes I think the 4 spots will surfice. So with the R32gtr and R33gtst they use the same rotor, but is the caliper the same?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMEWA%3AIT&rd=1
I was thinking something like this?
Also will the calipers I listed above fit on a 343mm rotor? I know I can fit them on a 330mm with out any problems.........
Hell anything is an improvment over stock! 289x23mm with a single piston caliper!
Cheers Dave
Edited by AirStrike
i c..
Here are the correct sizes:
R32 GTST
Front rotors (diam x thk) - 280脳30
R32 GTR (Non V-Spec,)
Front rotors (diam x thk) - 296脳32
R33 GTST
Front rotors (diam x thk) - 296脳30 Different caliper to R32 GTR but same disc diameter.
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Front rotors (diam x thk) - 324脳30
R34 GTT
Front rotors (diam x thk) - 310x30
The calipers that suit larger diameter discs have longer mounting legs to space the caliper out further.
When using R32 GTR calipers on 330mm discs I filed out the inside radius a mm or 2, i presume R33 is the same. R34 GTT mightn't need and mods.
R32 GTST
R33 GTST
R34 GTT
Hmmmmmm..............Any one know how to differenciate the calipers from each other?
Dave
  • 1 month later...
I have found this thread useful with thinking about a brake upgrade. It would be great as a sticky and would answer a few questions. Just knowing the stats of rotor diameter/thickness and the calipers.
Who makes these sticky's?? It would be great to compile this info into one thread.
Russell
I have the specs of a lot of Nissans in a spreadsheet, basically
R32 GTST
Master Cylinder diam (mm) - 25.4
Front Caliper Piston(diam x qty) - 40.4 脳4
Rear Caliper Piston(diam x qty) - 38.18脳2
Rear Rotors (diam x thk) - 297脳18
R33 GTST
Master Cylinder diam (mm) - 23.8
Now the interesting bit...
Master Cylinder diam (mm) - 26.9
Front Caliper Piston(diam x qty) - (44+38)脳2 ... leading pistons smaller then trailing
Rear Caliper Piston(diam x qty) - 40脳2
Rear Rotors (diam x thk) - 300脳22
