hi all,
the other day as i was driving to work, i noticed that my cluster looked a bit dim, then a warning signal from my turbo timer was displaying that i was only running 9.2 volts. got it to work and called RACV to look at it....
the RACV dood said that the alternators fine, but what the prob is the battery light in the cluster is blown and it wont allow the alt. to charge up the battery, i hav never heard of this prob and am still not sure that this is the case, just wondering if ne1 has experienced nething along these lines, or heard of the same thing????
NOTE:
- just tested the bulb in the cluster and isnt blown
- is a brand new battery but cheapo brand
can any1 help me?
thanx heaps,
Mark
https://www.sau.com.au/forums/topic/121712-alternator-not-charging/
to test it you may have to aply battery voltage to the alternator regulator feed. im not 100 percent on wich one of the two it is. (two pin plug on the alternator)
just use a test light with the aligator clip end on the car jump start points. (next to the engine bay fuse box)
and probe each terminal. youl here a whine when the alternator energises and it will start charging.
if it doesnt it is a shagged alternator. :P
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
