Garage Clearout
Ok time to clear out some of the parts in my shed due to moving house.
KKK K27 turbo, 600-odd hp turbo, t3 flanged ext gated ~1.00 rear housing. 76mm 40T compressor and 76mm turbine. Needs new seals as the exhaust side is leaking oil. (approx $600 for full rebuild) good for a rotor or rb30, was alittle big for my rb20 spooled at 5K. still made 220rwkw on 10psi though.
$300
Set of RB20DET R32 injectors - Sold
Set of RB20DET Nics HR31 Injectors - $40
RB20/25 Exhaust manifold - $40
HR31 HICAS Lock bars, replaces your rams with rose jointed bars. - Sold
HKS F-Con V Pro Version 2.1 for RB25DET, was tuned to run an RB24DET with twin injectors, K27 turbo, big front mount, etc. made 220rwkw on 10psi. - $300
Repco thermo fans
16" - $60
14" - $50
12" - $40
HR31 Headlights (not projector type) - $60
:P
Karl
Edited by kwazza11
Selling it due to being in adelaide and i changed the turbo setup so needed a remap, the only option was to buy another ecu or get it transported to sydney for a tune (yea right)!
email BD4's and ask them if they can rewire it to suit, they may even sell a loom for it if your lucky, i've done exactly the same thing with a power fc (used an rb25det fc with an rb20 loom) but it requires a few wires swapped around.
  • 1 month later...
 Share
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
    • I wonder if there is much to tell without knowing where the bolts where bought from. If it comes from Amazon or similar all bets are off. Can't trust them. And I fear not everybody knows that. Wasn't it @TurboTapin who ended up with the fake fuel lines recently? The submersible ones which very much weren't submersible at all. It kind of applies to everything nowadays. Doesn't matter if it's hardware or electronics. The fancy camera might have internals swapped out for cheap knockoffs. The hard drive will report a certain size but not actually be able to write it all. Shit like that. A bit depressing but the reality is you really have to be weary of where and how you buy stuff
    • My guess is, cheap rods, came from a site selling lots of cheap things, and likely a lot of knock off stuff.   I get doing a cheap build, but I don't get doing a huge dollar build, and then skimping on something even like the rods, and likely the bolts to go with it, especially if heaps of stuff had to be fabricated!
    • Today myself and a mate tracked a fuel pump issue down to this amazing piece of workmanship in the fuel cradle loom. Covered by conduit and electrical tape. so now we should be moving onto the first fire once this is corrected. 🤞🤔
    • 1000% percent the looks just aren't visible, I was shocked when i found out the the only thing holding the OEM diff ( rear side ) is one stud was can easily crack when trying to launch the car or really beating on it, hence why this brace connects to the subframe/control arms and even includes a fancy jackpoint, With the forced induction route, I would have quickly launched the diff out the back of the car without this upgrade. The Z1 and GK tech don't offer the same "cool" look so to speak.
