what replacement ecus for the rb25det don't use the afm. i have heard of some people talking about ecus that use a map sensor.
i am trying to twin turbo my rb25det. i am going this way as i already have 2 good rb20det turbos sitting at home. if i went for a large single i would have to change the ecu anyway. so i figured running the twin rb20dets which i already have would save me the $1000 or so i would have to pay for the large single.
can any body help me with any ideas on this matter.
thank you
https://www.sau.com.au/forums/topic/121793-replacement-ecus-for-rb25det/
microtech, autronic, do a search.....and you figure you can save money on a big single....you still have to get custom manifold made up for twin turbos custom exhaust etc etc......why dont you get a high flowed rb25det turbo.....theres the cost of your custom manifold and exhausts and all the associated crap that goes with a custom setup.....sell the two turbos you have make some money there
Edited by sinistagtst
Mate all the ecus these days tune the same
You are better off with either
Haltech E11 Plug N play
MicroTech LT12 Plug n Play
Wolf Plug N play
Hydra Plug N play
I'm curious about this hydra its apparently doing ETC and vairable cam timing isn't it?? Have heard they are working on a plug in for the EVO 9.
Wolf Plug N play
Hydra Plug N play
Thank you everyone for your help in this matter. MR331307 on the bottom of your reply it says about a 591hp r33. Is this your vehicle and if so what have you done to the engine to obatin this kind of power as it is the target power area that I'm tring to get too. About 600hp out of a rb25det in a s13 silvia should make for a very fun car.
Once again thanks everyone.
motec is basically a racing use ECU. it has many many features that an average bog stock skyline or even high powered skyline wouldn't use. it is simply not cost effective for a customer to use, given they can go for $1000 ecu and get 90% of the features they need. some of the features include
2 lambda sensor input
drive by wire control
rev limit per gear
down shift rpm matching for gearbox
3d map tables
choice of firing for upto 8 drivers
temperatre input/correction for air temp, oil temp, water temp
8 aux outputs for gate control, idle up, warning lights
porgrammable inputs (speed control for pits ie: lock speed to 50km/h)
full logging
basically rally cars and v8 supercars run motec as it has the features they need and use. gear logging for each gear and so on.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
