Hello all,
I have for sale a GCG XTRGTST-S1 turbo for sale. It's a stage 1 high-flow from GCG. As far as I can tell, it has steel wheels front and back, and is ball bearing.
The turbo is "plated" with the following details, and has GCG written all over it:
S/N: 016085
P/N: XTRGTSTS1
The compressor housing is labelled 16V 12 (R32 housing)
I had this turbo recently running on my R32 4 door. The turbo has no visible shaft play. It ran very well, but was laggier than stock. My mechanic and I agree that this turbo would be a good choice for an RB25DET, or an RB20 with alot of top end power.
The old owner of the car claimed that the car was dynoed at 187rwkw @ 15psi with NO aftermarket fuel system whatsoever. The turbo is rated at 450hp. The turbos are claimed to handle in excess of 20psi with no drama's.
Price Drop! Now going fro $1150ono
Contact me preferebly via PM, or e-mail. I'm located on the Gold Coast.
Email: fullofvitamins@hotmail.com
Can get better pics on request.
Cheers!
Edited by dbo
https://www.sau.com.au/forums/topic/121808-gcg-stage-1-high-flow-turbo/
Hey mate, how much more laggy was this then the stock turbo? Any idea when it made full boost, is this just the same as the GCG stage one hi flow thats $1950?
Also any idea on how many kms the turbo has been used for?
This is the same one that GCG will do for $1950. It would be the exact same as taking your R32 turbo to GCG, except alot cheaper.
This turbo is laggier than stock. I had a badly un-tuned R32 RB20DET, and I would make full boost (15 psi) at approx 4300rpm, with a stock fuel system. This turbo's efficiency point is somewhere like 6800-7000rpm, and can go higher than 20psi, so thats where you'll be seeing your peak power.
I would recommend this turbo to someone wanting more top end power, as the midrange isn't the best around. This particlar turbo woulds perform much better on an RB25.
I can only guess at the amount of kays this has done, but i'd say 12,500 wouldn't be far off. Turbo has zero shaft play.
  NathR32 said:
As above, and you might wanna change the price in your first post and add a 1 in there somewhere :)
Thanks for letting me know mate :)
Edited by dbo
  Phantom32 said:
so what sort of power would u get on an rb25?
~240kw? would the midrange be better on a 25?
265 rwkw with Tomei Poncams on an R34GTST
275 rwkw on an R33GTST with the slightly larger VG30 turbine cover (maybe worth 10 rwkw extra)
:laugh: cheers :O
:laugh: cheers :O
Thanks for that SD. I think it does actually have the VG30 turbine? (if not it looks like an R34 item)
As you can see this turbo can pull some nice figures at a good price.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
