My car currently runs 215/45/17 on the front, and 235/45/17 on the rear. My rims are 17x7 front, and 17x8 rear.
Im of the understanding that i could fit 215s all round, but is there any tyre performance issues other then those associated with reduced surface area, that would stop you putting a 215 on an 8" rim?
https://www.sau.com.au/forums/topic/12182-tyre-width/
That's a first!! I never heard of anyone wanting to go smaller in the rears.
I have F:245/35/19 and R:275/30/19. Have had no problems and just some minor rubbing of the plastic gaurd insert, as i turn up drive-ways. But the car does have a set of Tein suspension, which are relatively stiff.
PS: Gaurds have NOT been lipped, as i am not prepared to respray the car when the paint cracks.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-219222
Reason for wanting to go 215s all round was firstly im able to get some R compund track tyres for good $$$, but they are 215.
The guards on my R32 have been rolled and still anything wider then 235 on the rear rubs, and anything wider then 215s on front rubs.
I have had a set of work rims on the car with different offset that allowed 255 on rear and 235 on front without rubbing, but the 255s sat outside the rear guards, looked too 13B drag Corolla for my liking.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-220077
Hi Guys, tyre sizes do vary between brands, even the same brand has anomalies. We have 235/40/17 Yokohama A032R's on the front that are 239mm wide and 245/45/17 on the rear which are 243 mm wide. So 235 versus 245 should be 10 mm wider, but they are only 4 mm wider.
Oils ain't oils, Sol.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-221651
I have 235/40/17 on the front and 255/40/17 on the rear...
I have noticed that the front tyres wear unevenly now...
The inside 1 inch wearing bald while the majority of the tyres are chunky as...
Anyone else getting this ?
I am told that sometimes Skylines do this, or that wide tyres cause this...
Also finding that the guard-liners are wearing against the front tyres somehow...
Thing is, I've had it for years and its only started doing this in the last year...and I can't figure out if it is worn suspension or my driving on corners...
The initial indicator I noticed in the area was that the guard liners pop to the outside of the guard lip, and I have to sometimes push them back in behind them...
I'm interested to find if others have any similar signs...
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-233736
Last time i got a wheel alignment i started going thru front tyres...too much camber.
Didnt notice any difference either by feel, lap times, or in consistancy so have dropped some camber out of the front. Tyres seem to be wearing better now.
You R33 owners are spoilt, just like my friend in his 200SX, your guards swallow 18s, even 19s, or nice and wide 17s.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-235215
What you mean OR, i have the best of both: 19" x 8" rims all round with F:245/35/19 and R:275/30/19. :D :shake: :) :shake:
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-235548
Hi PuppaDuck, tyres wearing on inside = too much negative camber or incorrect toe settings. Puting wider (or narrower) tyres on should not affect the suspension geometry. Either way have it checked. Toe should be set at zero or slightly toe out. Camber is a little more tricky as it depends on your driving style. Anything more than 1 degree negative on a road car can be a problem.
If you like the handling feel of negative camber, try more caster instead. All of the advantages, but no increase in inside tyre wear.
Hope that helps.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-236470
Thanks SydneyKid...
I'll put this to the next guy I go to for a wheel alignment...
I have no personal choice nor do I know what to ask for...
But if I can get front tyres to last longer than a year by wearing even then I'll be happy...
Maybe he was put off by not knowing what settings to put it on cause the R33 isn't in his book...or perhaps he wasn't sure about the HICAS...
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-236478
Hi PuppaDuck, since HICAS is rear steering I have no idea why that would effect what he thinks should go on the front. I'd find a better wheel alignment shop. We use Whiteline (Wedge) at Minto or Heasmans (Doug) at Sydenham. East Coast are also OK.
The "local tyre shop" is generally a waste of time.
Hope that helps.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-236946
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
