My car currently runs 215/45/17 on the front, and 235/45/17 on the rear. My rims are 17x7 front, and 17x8 rear.
Im of the understanding that i could fit 215s all round, but is there any tyre performance issues other then those associated with reduced surface area, that would stop you putting a 215 on an 8" rim?
https://www.sau.com.au/forums/topic/12182-tyre-width/
That's a first!! I never heard of anyone wanting to go smaller in the rears.
I have F:245/35/19 and R:275/30/19. Have had no problems and just some minor rubbing of the plastic gaurd insert, as i turn up drive-ways. But the car does have a set of Tein suspension, which are relatively stiff.
PS: Gaurds have NOT been lipped, as i am not prepared to respray the car when the paint cracks.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-219222
Reason for wanting to go 215s all round was firstly im able to get some R compund track tyres for good $$$, but they are 215.
The guards on my R32 have been rolled and still anything wider then 235 on the rear rubs, and anything wider then 215s on front rubs.
I have had a set of work rims on the car with different offset that allowed 255 on rear and 235 on front without rubbing, but the 255s sat outside the rear guards, looked too 13B drag Corolla for my liking.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-220077
Hi Guys, tyre sizes do vary between brands, even the same brand has anomalies. We have 235/40/17 Yokohama A032R's on the front that are 239mm wide and 245/45/17 on the rear which are 243 mm wide. So 235 versus 245 should be 10 mm wider, but they are only 4 mm wider.
Oils ain't oils, Sol.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-221651
I have 235/40/17 on the front and 255/40/17 on the rear...
I have noticed that the front tyres wear unevenly now...
The inside 1 inch wearing bald while the majority of the tyres are chunky as...
Anyone else getting this ?
I am told that sometimes Skylines do this, or that wide tyres cause this...
Also finding that the guard-liners are wearing against the front tyres somehow...
Thing is, I've had it for years and its only started doing this in the last year...and I can't figure out if it is worn suspension or my driving on corners...
The initial indicator I noticed in the area was that the guard liners pop to the outside of the guard lip, and I have to sometimes push them back in behind them...
I'm interested to find if others have any similar signs...
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-233736
Last time i got a wheel alignment i started going thru front tyres...too much camber.
Didnt notice any difference either by feel, lap times, or in consistancy so have dropped some camber out of the front. Tyres seem to be wearing better now.
You R33 owners are spoilt, just like my friend in his 200SX, your guards swallow 18s, even 19s, or nice and wide 17s.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-235215
What you mean OR, i have the best of both: 19" x 8" rims all round with F:245/35/19 and R:275/30/19. :D :shake: :) :shake:
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-235548
Hi PuppaDuck, tyres wearing on inside = too much negative camber or incorrect toe settings. Puting wider (or narrower) tyres on should not affect the suspension geometry. Either way have it checked. Toe should be set at zero or slightly toe out. Camber is a little more tricky as it depends on your driving style. Anything more than 1 degree negative on a road car can be a problem.
If you like the handling feel of negative camber, try more caster instead. All of the advantages, but no increase in inside tyre wear.
Hope that helps.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-236470
Thanks SydneyKid...
I'll put this to the next guy I go to for a wheel alignment...
I have no personal choice nor do I know what to ask for...
But if I can get front tyres to last longer than a year by wearing even then I'll be happy...
Maybe he was put off by not knowing what settings to put it on cause the R33 isn't in his book...or perhaps he wasn't sure about the HICAS...
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-236478
Hi PuppaDuck, since HICAS is rear steering I have no idea why that would effect what he thinks should go on the front. I'd find a better wheel alignment shop. We use Whiteline (Wedge) at Minto or Heasmans (Doug) at Sydenham. East Coast are also OK.
The "local tyre shop" is generally a waste of time.
Hope that helps.
https://www.sau.com.au/forums/topic/12182-tyre-width/#findComment-236946
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
