Niigata / Maze Circuit
Guest Mashrock
i found a sticker the other day in my car. it was under my rollcage padding
i have had the car for over a year now. haha
it reads
Sunday racing cauce
Maze circuit
team nihonkai
there is a photo of it. but its a bit hard to get a photo of..
wonder if i can track down the owner. wouldnt mind some info on the car. or the engine and what they have done to it as there is lots of aftermarket shit and non standrad internals
https://www.sau.com.au/forums/topic/121824-niigata-maze-circuit/
a quick google search brought up the following:
this is from nagaoka (2nd biggest city in niigata) - orange FD is a nihonkai car
http://nagaoka.rgr.jp/ibent/dynamaite/index.html
http://www.medianetjapan.com/2/20/sport/ka...gotoibento.html
here's a site for the circuit:
http://members.aol.com/Mazecircuit/index.html
that might be a good starting point for investigation.
Guest Mashrock
so nihonkai mean what exactly?
my mate has done japanese for a bit but said it has many meanings.
i know nihon is japan. then i asked my friend and kai can mean shellfish. can mean levels in a building, and a gathering/party..
but once googled on that orange fd it came up team sea of japan..
the textbook japanese translation of nihonkai is the sea of japan. However the stickers meaning could mean anything
Although judging by the kanji the left 2 have no idea because of the photos angle the far right one appears as though it could be 海 beach, sea, ocean.
Also looking at one of Daioni`s links the orange FD with `Team 日本海` basically shows that theres some kind of race team called nihonkai
anyways :dry:
Edited by akeenan
Guest Mashrock
Certificate of originality on my rear window.
Peep the OG decal (anodized red/silver) that I got from the manager of the Nihonkai Maze Circuit in Japan. I saved it from our Tokyo Auto Salon excursion in January 1999. The most popular things to race at the Maze are motorcycles and hachirokus!!!
http://members.tripod.com/~teamcipher/doriftoREDae86.htm
from some honky website.. uhoh!
p.s. the photo didnt work but its at the bottom of link
Edited by Mashrock
yeah i'd say the previous owner probably bought the sticker at TAS or a shop to put on his cage cause he thought it looked cool, or maybe he had been to maze circuit? i would say there would be many of those stickers on peoples cars.
just get someone to have a look at your turbos and whip off your sump and that should give you some idea about what is on the car. or do you have the japanese registration (or de-registration) or auction sheet?
kai also means modified
so it could translate
Japan Modified
implying Japan Modified Car Club etc
and i don't know if you knew or not, but Maze would not be pronounced in the way we would say maze (not a puzzling series of turns designed to get you lost)
rather it would be pronounced MA - ZE
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
