is there sumthing i can set it on to start with or shuld i just install it and not hook up the wires to change the A/F Ratio.
Initialse the unit, select your AFM etc and make sure that all the corrections are set to 0%, that way it wont affect the base map.
Or for super-mega-extra power set them all to at least -20%. (NOT)
Brent.
https://www.sau.com.au/forums/topic/121827-safc-settings/#findComment-2246887
road tune is good enough for SAFC, if you can borrow an wideband o2 sensor
If you cant borrow o2 or can't be bothered tuning it yourself, take it to anywhere that does tuning. 1 hour max dyno time and it should be sweet, that's usually $100-120 or so at most places
https://www.sau.com.au/forums/topic/121827-safc-settings/#findComment-2247426
