Am unsure whether this is exactly the proper place to post this question up.....
for those who know how the power window mechanism works....wut has happened is, the bar that is in the shape of a X, the lower part is connected to a horizontal rod with bearings(the horizontal rod is attached to the window), it has poped out of this horizontal rod, and the X bar am referin to has bent.....my main problem is am finding it hard to access this area.....
Can anyone please give me some insight into how to access this area, so that i can straighten out this X bar?
Thankyou in advance.
Your in luck, I just got rid of an annoying clacking sound in both my windows and did a photo step by step of how to get to the bolts and tighten them. You will want to remove these bolts and as you can see in the diagram there are washers each side to remove as well. To get to them you have to wind the window down, when you get them, wind it up to get the next one and up again, put your finger on the back to stop the bolt spinning. Remove the glass then undo the winder bolts, I dont know if it is better wound up or down to remove from door but you get the idea.
Others on here might not of removed door covers before so I added all the steps for right and left. for the right, the control panel has a clip in the centre that goes in the hole in the rusty clip, the door release handle surround has clip points on the thin side, top and bottom and pulls out as well. The left side needs the window control pulled out to accces screw deep inside and a panel below that to access the other screw. Once that is done remove 3 screws along the bottom and gently unclip panel around edges, lift the panel to remove from door as it is hooked along the top over door frame.
window2.bmpR33S2, thank you for your response. certain things are unclear to me, but since you put up pics, I can now explain clearly what has gone wrong and clear some doubts.
I have marked in the picture the ends of the X-bar and marked which one has bent. I could not get access to it to straighten it out. My question to you is whether this X-bar comes off when you remove the winder retainers that you have marked.
on another note, the ends of these X-bars are attached to a horizontal bar which is inturn attached to the actual window. it is clipped into two white bushes which are on the horizontal bar, any idea where i could get them, as both of them have cracked, so the ends of the X-bar keeps popping out of them.
Thank you in advance....
Edited by dan22
Your pic link isnt working.
The whole thing comes out of the door, first undo the glass and remove it then undo the winder and remove that, then you can work on it.
In my experience once the winder parts have bent or broken it is easier to replace the whole thing, because I have usually had to buy the whole thing to get parts for it. lol you may get away with a Xpeice from a non electrical one.
i have no idea how to get the pics as thumbnails, like how u have done it.....but still, my questions have been answered.....ha ha....
now its gettin down to it.....i'll probably start over the weekend, n if i run into any problems, u will surely receive a PM from me....lol....
thanks again mate :P
No problems, to add pics click the 'add into post' after the upload.
If your buying from a wrecker take the old one with you, just hope it doesnt rain :)
i tried that to add the pics, but did not work..... :D
goin to a wreckers is generally a sickning experience.....ha ha..... :
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
