EMZ R33 Posted June 11, 2006 Share Posted June 11, 2006 Hi all, just a quick query about my climate control in my R33. My car needed to be jump started the other day and post that my climate control wont turn on at all. None of the buttons work and ive checked all three fuse boxes (boot, under dash, and in engine bay) and no fuses are blows. I have heard that disconecting the battery and draining all power from the car may cause the computer to reset and possibly fix the problem. I dodnt want to start fiddling around with the battery if this wasnt the case. If anyone out there knows anything about this issue it would be great to hear bout it. Kind regards Evan Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/ Share on other sites More sharing options...
paulr33 Posted June 11, 2006 Share Posted June 11, 2006 ecu reset wont fix it, i suggest auto elec to debug it Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/#findComment-2247966 Share on other sites More sharing options...
EMZ R33 Posted June 12, 2006 Author Share Posted June 12, 2006 All fixed lads, with a little help from my girlfriend (she put me to shame)!!! She also found a pdf file on the net titled "The Sky is the limit" which is a very insightful read. Regards Evan Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/#findComment-2248491 Share on other sites More sharing options...
VB- Posted June 12, 2006 Share Posted June 12, 2006 so what was actually causing it? Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/#findComment-2248629 Share on other sites More sharing options...
Mr Italy! Posted June 12, 2006 Share Posted June 12, 2006 She also found a pdf file on the net titled "The Sky is the limit" which is a very insightful read. Do you mind posting up a link so we can have a read too? Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/#findComment-2248649 Share on other sites More sharing options...
r32line Posted June 12, 2006 Share Posted June 12, 2006 She also found a pdf file on the net titled "The Sky is the limit" which is a very insightful read. Does the article have information on more than just r33's? Either way, i would also like a link to it. Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/#findComment-2248720 Share on other sites More sharing options...
sloazr33 Posted June 12, 2006 Share Posted June 12, 2006 is this the one? The Sky Is The Limit Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/#findComment-2248757 Share on other sites More sharing options...
r32line Posted June 12, 2006 Share Posted June 12, 2006 Thanks very much for posting that article, i found it pretty interesting, and its the first clear explination i've read of the self diagnosis for the climate control unit on the r32 Link to comment https://www.sau.com.au/forums/topic/121870-r33-climate-control/#findComment-2249678 Share on other sites More sharing options...
