gday guy i was just after some info on building a 350-400awkw gtr. this is a long tearmish kinda goal to acheive
keeping it at the 2.6L...many a slight bore, but not stroking it out. also using low mounted twins that are direct bolt on if possible. is this able to be acheived.
at the moment the car if off the road and is about to receive a rebuild so im hoping the parts that will be able handle that kinda power figure.
have the computer ready to go in. then there will b some money spent on other things such as new suspension set up etc. a lil maintanence to the car...that kinda stuff
is this able to be acheived??
cheers
https://www.sau.com.au/forums/topic/121898-building-a-350-400-awkw-gt-r/
All you need is alot of money that you'll never see again >_<
Engine will need complete rebuild if you want any sort of longevity.. forged pistons/rods, everything in the head. Fuel supply will need to be substantial, as support systems, ECU, boost controller, intake, exhaust etc etc etc $$$
Don't forget suspension, wheels/tyres and brakes!
Edited by Morgs
basically you will need a built motor with cams, a decent fuel system (pump, injectors etc), ECU, upgraded AFMs, HKS 2530s and all the support gear, like oil cooler, sump baffles and oil system mods, clutch upgrade, possibly box upgrade (depending on how you drive it), little things like EBC, new cooler, good gauges etc etc. It will be a fun car though.
With an RB26 u'll be looking at $15,000+ if you want something that will last and still pull out those figures. Someone who I know has R32 gtr had a full rebuild and is a complete beast and has spent about $20k so yeh not a cheap project at all.
some of that i think depends on the use of the car
being street or track etc
cheers
YES very achievable as there a number of rb26 low mount twins running this awkw around the place.
Equipment needed
Turbos .Garret Gt2560r 707160-5 or the HKS 2530 (these are the best two choices for what you want)
Ecu. Apexi PFC (only choice in my option for street gtr)
Afms. RB20/25afms (up to 530rwhp)and Z32 afms over this level (descreen the afms is good tip)
Injectors. 700cc sards
Cams. Tomei poncam 260deg 9.15mm lift or similar HKS etc
Cam Wheels. Tomei make great units but any will do the job (yes very importane in the final tune)
Exhaust. You need dumps and full exhaust (3 1/2" is good or twin system)
Fuel system. The r32 needs a direct power supply to the fuel and most likely a pump upgrade the r33 and r34 can make the hp if the pressure is not altered on the std system.
I would note running this power for any length of time especially in a r32 you will need forged pistons and a set of arp rod bolt (atleast).
there are many other nice things you can add but i have just listed what i have found you will need
Pete
ps as for the cost of all that well it variies to much and also weather your willing to work on the car yourself
Im looking at the same amount of power in my gtr as well.Good to see someone else is in the same boat as me.
Pnblight does the Garret Gt2560r 707160-5 have the same specs and spools at the same revs as the HKS2530 ?Just wondering because I hear HKS basically sells Garret turbos but with the HKS name,so want to know if theres any difference besides the names..
Cheers.
Cheers.
ok the hks2530 do spare some parts with gt2560r ie turbine wheel and housing but the garret run a different compressor wheel and to try and explain the difference from what i have seen it the garret spool better and are more efficient below 1.5bar but the hks 2530 can really come in to there own after 1.5bar.
The garret gt2560r 707160-5 are the best early spool and low end hp i have seen reliative to there potient.
3500rpm ~135rwhp
4000rpm ~180rwhp
4500rpm ~240rwhp
5000rpm ~360rwhp
5500rpm ~435rwhp
7500rpm ~529.4rwhp
so as you can see the power is early and quiet linear to explain by seat of the pants ride the engine pulls from 3000rpm and the its on turbos and hailing by 4000rpm which makes it an awesome track car, very fast and user friendly.
pete
ps hope that helps
This will give you an idea on pricing. This setup was $15000 drive in / drive out tuned.
Standard Rb26 internals.
GCG high mount manifold, GCG 35/66 SPL, Turbosmart progate 48, Sard 650cc injectors, Bosch 044 fuel pump, Apexi D-Jetro ECU, Tomei adjustable cam gears, Gates timing belt, Custom dump pipe, cooler pipes, intake pipe and filter, custom power steer resovoir, Speedflow turbo plumbing. Eboost 1. Includes labour for removal and fittment of all parts. Tune at Unigroup.
Note that no engine internals have been done, you can safely add Another 10k+ with a engine build.
cheers
Edited by BezerkR32
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
