Hi guys,
I was thinking of swapping the turbo in my 1995 R33 GTS-T with one from an R34 Neo engine. Is this a worth while swap? Has anyone done this before? I assume the R34 turbo is a little bigger?
Any comments would be appreciated.
I would stick with your turbo as it has a steal compressor wheel and will take more punishment then the R34 turbo because they are ceramic/plastic. They tend to break/melt under boost.
Correct me if I’m wrong but I believe the R34 turbo is only slightly bit bigger in the flange but I wouldn’t think you will feel the difference.
Not worth a sent in my point of view.
Cheers,
Alex.
Cheers,
Alex.
the comp wheel wont melt under boost.
the rear wheels are the same R33/R34, ceramic... and they all fail.
the R34 turbo has a larger rear housing aswell
