hi i am interested in buying this manifold
one of the reasons why my engine blew was because the stock manifold was leaning out #6 so my next build up, i don't want to have the same problem
will this be solve the problem?
have anyone dealt wiht this guy
how are these ebay manifolds ?
thanks
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT
There is more to the #6 leaner issue than airflow, it is also the hottest running cylinder. It is the furthest from the water pump, it is the furthest from the oil pump, it gets the hottest air flow etc etc.
What we do is tune the primary pipe temperature so they are the same. Put the highest flowing injector in #6 and then trim the fuel in all the cylinders to give the same exhaust gas temperature.
I have yet to find a "perfect" inlet system at all practical boost levels, aerodynamics is like that.
:dry: cheers :wave:
Nah... flow testing the injectors before u stick em in.
They are never perfect. One will flow more than another.
So, you put the highest flowing one in the rear :dry:
Then there is tuning stuff, which someone else can input as im not sure on it.
Or you could go dual entry fuel rails. They have been debated in the past (search button for that)
We are already tested on of our customers drag racing cars, these car are 1000++ whp. These cars run fine on very high boost(2.5 psi) no air leak, no crack on our manifold. If you are looking for very best quality manifold for your engine this is the one.
dont you just love dodgy ebay.. if your goin to buy a intake.. spend the money on a decent brand named one.. not a dodgy ebay one :
Edited by rb26s13
haha, yea i thought that was kinda funny..."if u want the best, this is the one" then you wonder why they sell for 1/4 the price ... hahhaha
so what happens if i get new injectors, shouldn't they all be the same ?
do you suggest i flow test the new injectors ?
thanks for all the help guys
So, you put the highest flowing one in the rear :(
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
