In my r30 skyline. i was driving along the other night and randomly the following lights came on and occacionaly flick off for a second but then come back on.
If the car is under 1000rpm they dont come on, they once I rev it they come on and stay on. Sometimes go off for a sec when i stop or turn.
The lights are:
Door open Light, Coolant Overflow bottle light, Fog lights light, Window washer light, fuel light, and the spare tire light which is not on the dash but next to the interior lights on the roof.
PLEASE HELP!
From George
https://www.sau.com.au/forums/topic/121925-dash-lights-on-help/
hey george
had this problem before i think, all the lights come on right? my car had the door open, coolant overflow, overheated, window washer etc etc.
took it to an auto electrician, turned out to be buggered alternator or something. $200-odd dollars i think it was (i'm located in perth though).
Its kinda tough how much it SHOULD cost, cos i have nothing to compare it against (if anyone's had it cheaper, forum whore's had the same problem and fixed it for half the price, etc etc).
Good luck with the fix :)
hey george
Repco has alternators for under $200. So i'll go get one from there.
yep sounds like a charging problem. could be as simple as the fan belt loose/slipping, or wire fallen off the back of the alternator. Or it could be the alternator itself, but it pays to chack the basics first. Normally in the Bosch type alternators, its just worn brushes. These are replaceable without removing the alternator, and will cost alot less than a reco/exchange alt. If it turns out you need a replacement alt, I'd get one from a auto sparky. They're normally cheaper than repco in my experience.
can anyone tell me what the 2 warning lights on the R30 dash that look like headlights mean? There are 2 of them, one faces left, and right next to it the other faces right. I intermittently get the one on the right lighting up when the headlights are on. What the hell are they?
Edited by hrd-hr30
In the top l/h corner. Twoheadlights. The one on the left is blue for hi beam, the other comes on when you brake then goes out. If it on all the time you have a blown globe some where.
doesnt come on or go out when i break. it does nothing until now
thanks. all the lights were working. It's only on intermittently when the lights are on, half the time its not lit up at all, and it flickers at times too. Maybe I should check for a loose wiring at one of the lights...
I think all the lights on is an altenator problem. Been there done that.
The two head lights on the dash are, as I said, blue for hi beam. The other on the right of the blue comes on to signify that you are braking and the brake lights are working. No braking, no light. If the light is on all the time even if the headlights are not in use it means you have a blown globe in the stop light system. In 23 years of owning my RMR30, the only globes i've had to replace are three l/h stop light globes.
Hope this helps.
Hope this helps.
sorry about confusing the issue. I agre if all the lights are on, its a charging problem. That was happening when my fanbelt was slipping when i first got the car.
aha - I did have a stop light out! all fixed now! why does it look like a headlight if its a stop light??? now if it looked like a stovetop hotplate I would've got it... :thumbsup:
  • 3 weeks later...
yep sounds like the alternators not doing its job as well as it should. if its not that, try whacking the dashboard. could be a loose connection.
i changed the alternator and its still happening......
Is it like you first mentioned? If so I suggest you get a propper diagnostic checkup.
The only time I had a heap of lights on the dash was when the altenator shit itself. I got it fixed and bugger me it did it again. Turned out the "new" altenator was faulty.
How should I go with diagnosing a fault like this?
If the problem is still ther you will have to get a GOOD auto electrician with all the diagnostic gear. Try the Yellow Pages
Pitstop Books in Perth have manuals for R30 if you need one. About $100 but a must have. I got one last year and it has saved me heaps.
Does it have anything on the FJ20 in it
no ti doesnt. and i got a r30 manual for $3 last year. But how is taht going to help me fix this? there is no fault in here to do with whats happening to my vehicle.
SERIOUSLY! I'm sure someone here can help. half of you seem to be extremely knowledgable. PLEASE HELP!
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
