Hello again all!
In about 3 weeks I'm going to lose my licence for 6 months (I was on a good behaviour licence, and the defected my exhast and I lost the one point :dry: )
Anyway,
So I have 6 months to slowly do something to my car. Can I have suggestions as to what to do to the engine, like Id like to fully rebuild it slowly and as money prohibits, so what sorta things should I be doing whilst its apart so squize a few more ponnies out of her.
Exhaust is already done (Which I bottomed out, and flattened my nice shiney tip), timing is great, Injectors are WAY too much!.
Ideas on what other peopel have done, cost's, where to buy stuff like that would be great! Thanks
https://www.sau.com.au/forums/topic/121936-rb20de/
Yeah but NOS isnt legal for the street... I would swap it out for a rb25de or even a rb20det...sooooooo cheap these days :D
But the NOS kit itself isn't illegal is it? Your just not allowed to have a bottle hooked up unless your at a track or somewhere like that. I think that's how it is in WA anyway.
RoD
https://www.sau.com.au/forums/topic/121936-rb20de/#findComment-2253218
Thats correct. Nitrous can be installed in your car, as long as the nitrous bottle is not hooked up to the end of it... everything is a risk though these days. Lowering a car too low is illigal, so is getting wheels 2" bigger, and so are loud exhausts to name a few. As long as you dont act stupid your very unlucky to get caught. But in the end its your choice, best bang for buck mod and i would definetly reccomend it:) Specially for a NA.
Dayne
https://www.sau.com.au/forums/topic/121936-rb20de/#findComment-2256337
Hey Rancher. Looking at your avatar, I would say you’d want a air box around your filter. It's also beneficial to duct some cold air into there as well.
There's no point trying to get more power out of a motor if your plugs are crappy, so some new sparks and a general service of the engine can help too. Extractors can add that little bit more too, if you haven't already done them.
Once everything is in top shape, I would recommend getting the car dyno tuned, you may be surprised how well a good RB20DE can go.
Finally, and the cheapest mod of all, weight reduction.
The one thing the 2ltr really hates is weight, as the motor isn't as torquey as the bigger RB's. A light R32 GTS can really give higher-powered Skylines a run for their money.
https://www.sau.com.au/forums/topic/121936-rb20de/#findComment-2260278
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
