Selling skyline 97 r33 s2 GTS-T his the first person in Aus to own this car its been here just under 2 years its got cat back exhuast, Apexi turbo timer, kenwood head unit alpine fronts and pioneer 6in rears with tweeters clarion amp with 1 year rego 80,000kms,
this car in immaculate condition insideout best condition one youll find not like others with brown coloured front lights
0416264296
$13,500
a bargin for this pics are abit shit tho will get better soon
Also this car was mostly driven by his misses reason for selling need a new ute
NO SWAPS UNLESS ITS FOR A NEWISH UTE IN SYD/ACT
http://i6.photobucket.com/albums/y227/andyssx/OURTOYS029.jpg
http://i6.photobucket.com/albums/y227/andyssx/OURTOYS028.jpg
http://i6.photobucket.com/albums/y227/andyssx/OURTOYS027.jpg
http://i6.photobucket.com/albums/y227/andyssx/OURTOYS026.jpg
http://i6.photobucket.com/albums/y227/andyssx/OURTOYS025.jpg
THANKS
Edited by 1SX:2NV
https://www.sau.com.au/forums/topic/121977-97-r33-gts-t-skyline/
  • 1 year later...
  • 1 month later...
  • 3 weeks later...
Hello... Clean looking ride. Where abouts are you located. In other mods apart from the ones listed? Do you have the service history? How often is it serviced and where? Also, do you still have the importation paper work?
As I said an extremely clean lookin R33 can't beleive there is not much interest. Even if I'm not interested a few of my boys are also after a toy car for the weekends.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
