Was driving home today from echuca and was playing around with...the car and twisted the end of the wiper handle/switch/arm thing. i noticed it when i first bought the car but forgot to ask....
Its a twisting knob, with 3 settings, on the end of the wiper handle and it has a little gap next to it that indicates the amount of whatever it is.
I have 2 guesses at what it is:
1. Regulates the amount of water from the washers
2. Sets how far the wipers sit under the bonnet.
Anyone know for sure what it does ?
https://www.sau.com.au/forums/topic/121978-windy-thing/
dude if its what ur describing. all cars have it, it controls the speed of the wipers when in the intermittent mode. :)
lol i wish it set how far the wipers sit under the bonnet thou. bloody shits me when i'm cleaning my car and can't put the wipers up. other then that they do look good when not in use been hidden and all.
Edited by skypy12
https://www.sau.com.au/forums/topic/121978-windy-thing/#findComment-2249542
dude if its what ur describing. all cars have it, it controls the speed of the wipers when in the intermittent mode. :banana:
ahhh excellent. I was reading in my manual that there is a switch that you can flick to make the wipers stop higher. I think it is snow mode or something.
Gonna test out the intermittent mode. wooooo
https://www.sau.com.au/forums/topic/121978-windy-thing/#findComment-2250408
konect... is one of your reverse lights red as well? or do you have any rear facing red foglights? Most "snow area" cars in japan have em. Surprised your A31 isn't AWD... most of the GTS4's come from snow areas and a lot of AWD ceffies too.
https://www.sau.com.au/forums/topic/121978-windy-thing/#findComment-2256704
i didnt mean snow mode as in traction control or anything. Just remember reading that the switch I was talking about on the wipers is meant to let them sit higher so you can put them up in the snow.
not sure if my car has it :D its in the garage and I cbf going to check.
Also in other news I bought some late model taillights. wooooooooooooo!
Edited by konect
https://www.sau.com.au/forums/topic/121978-windy-thing/#findComment-2256723
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
