i dont like my 3.5" exhaust with a 4" cannon.
the exhaust is too big, so it sits too low under the car, and i hate the look of a milo tin hanging off the back.
im essentially after a twin 2.5" system, with a 3" chrome tip on either side of the rear bumper.
much like this.. (yes its a stinking holden, but it has the style i like :))
anyway..
where would i go to get something like this, and is it do-able?
is there room on the right hand side of the car to run the exhaust, or can twin pipes be run down the left hand side, and the second pipe crosses over to the right after the diff?
give me answers and/or suggestions!
ps. if it works, anyone want to buy a 3" trust dump + really high-flow cat *wink* + 3" -> 3.5" expanding exhaust, with a 4" tip? ;)
https://www.sau.com.au/forums/topic/121990-twin-exhausts-on-a-r33-rb25det/
probably about $600?
its in pretty good condition, dump pipe is powder-coated, with a small scratch on the bottom, and the cannon has a bit of scratching and a small flat spot on the bottom.
yeah, ive seen that style... i like it better than what i have now.
however i still prefer the single tip on either side :)
might ring a few exhaust places and see what the verdict is..
if it can be done on a GTR, i cant see why not on a GTS-T.. both have the same exhaust channel on the left.
yeah it would creat alot of extra un-needed piping making it more expensive? the twin exhaust on the Monaro/350Z/300ZX etc is like so as its easier to run twin pipes either side of the V-shaped motor. The inline six of the RB25 make sense to have the single pipe down 1 side.
I hear ya mitchy - Love the twin tailpipe look :banana:
P.S. You wouldn't need to sell your old exhaust, just the rear section really.
You can get any exhaust shop to weld you up a nice twinpipe system (from say the rear-diff backwards) - the only real cost would be in the twin mufflers.
How you'd go with in-cabin drone is another story but!
Good luck, and don't forget to post pics when you're done!
Try Genie exhausts, they may be a little more expensive than some places but theyre generally competetive and always have a good end product.
60 Norma Rd
Myaree, WA 6154
Daily 8:30am- 5:30pm
Tel: (08) 9330-6900
Fax: (08) 9330-2514
i think street force built that LS1 R33 which has a cannon muffler exiting on each side. give them a call. i'm sure any competent performance exhaust shop could make it, not sure how much room you'd have for piping underneath the right side of the car though.
60 Norma Rd
Myaree, WA 6154
Tel: (08) 9330-6900
Fax: (08) 9330-2514
if you want my feedback from past experiences with these guys, pm me :D
I hear ya mitchy - Love the twin tailpipe look :)
i was thinking about just doing the rear part after i posted..
just before the dif, and back, should be all i need, because its only really where a 3.5" mandrel bent pipe passes under the dif shafts does the exhaust cause any problems for bottoming out, etc.
emailed mettams and they doubted it would fit with the stock fuel tank.. but i reckon with a bit of creative thinking, ill get my twin tips ;)
ps. with the twin tips.. i was thinking about putting one of those apexi exhaust control valves on one side..
ie. when i dont need power or noise i can make it run off just one 2.5" exhaust, and when i want to give it a squirt, open it up for twin 2.5" goodness :D
just do what im doing with the stagea - 3 inch to the diff, then split, with a 2.5" going to each side, with cannons.
dump pipe, cat, length of pipe, magnaflow muffler, resonator tuned for 2000-2500 revs, or 2500-3000 revs to stop drone, then length of pipe back to diff, splitter, 2'5inches each way, to cannons.
brilliant. but expensive, maybe $1300 depending on brand-name parts or not.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
