hey guys
was wondering if the GT30R internal gated will fit in the stock low mount position of the factory turbo
if so is it an easy fit or a tight fit and are the water and oil lines easy to setup for this
cheers guys
andrew
well there are no int gated housings at this stage in that line... still not out from garrett...
So what housing have you had machined up?
What A/R is it?
Is it a R33 rear housing? VG30?
garrett has a line of them in internal gate, its on horsepowerinabox site and racespec site
A/R they have are 0.63, 0.82 and 1.06 i want the 0.63 for quicker spool
and im not to sure what housing it is but mounts onto my t3 manifold
That is a custom made jobby from hpiab. They are a VG30 second hand rear housing from memory.
Garrett is just about to release the intrnal gated GT30R this month. I should find out this week.
In answer to your question though...the turbo will need to be spaced away as the comp housing is rather large. The oil and water lines will need to be made up. I suggest braided. These can be made for around the $250 mark. The inlet will also have to be changed due to the large turbo mouth.The dump pipe angle will also change so you might have to cut it under the car and rotate then re-attach.
As 3lit said, they are not on the market yet.
So you've got the VG rear... alhough im now worried about what comp wheel it has in in...
But on the matter at hand, as 3lit also said, youll have to change all the stuff around it
havent they been out at gcg and unique autosports for ages..... we are talking bout the gt3040 arent we???? if so someone else on here has done it in the stock position i remember lookin at it has the whole install process on photos, i think its in the forced section
Edited by sinistagtst
i havent got it yet aye im just hell interested in buying one when they come out or if they are available atm
for around the 2k mark there the only turbo from garrett that are rated for more than 400hp
well they are a hybrid, not an "offering" from Garrett at all
What about...
http://www.gcg.com.au/Catalogue_Menus/Upgr...pgrade_gtst.htm
Another hybrid, well tested, well proven
well im tossing up between that gcg highflow or a gt30r but gt30r more work to be applied to make it all fit in and running where as the gcg is all staight in straight out
my aim for the car is to get 350 rwhp
GCG Ball Bearing High Flow on the Group Buy for $1750 delivered with all the parts necessary to fit straight on.
http://www.skylinesaustralia.com/forums/in...howtopic=121128
:P cheers :)
If you want 350rwhp an you get the gcg high flow factor in doing your cams as well, I have searched on these forums and not that many high flows have reached your figure of 260 rwkw.
The GT30R will be able to achieve this figure easily with more tuning maybe more, I have had a good look into the two myself. Im going with the GT30 I guess it depends on a few other things though as well like wat are you wating to do with 350rwhp ,track ,drift ,1/4. Wat other supporting mods would be in place to back up the turbo.
well the car is set for track
i have pfc, fmic, pod, z32, ebc, fuel pump and fuel reg, turbo back zorst and when i get the turbo ill get bigger injectors
my car is tuned at 261 hp on a base/safe tune due to my turbo seal goin it cant be tuned for more otherwise bang
*sigh* they are external only.
any internal models are having other housings machined up to suit as the garrett items are not yet released
if people cant understand that yet i give up
have seen a similar turbo low mounted, it was off the new falcon, featured ar.7 compressor cover and ar.82 rear internally gated. extensive modification of the engine mount necessary. plus custom plumbing in speedflow for oil & water feeds and custom dump pipe, intake pipe & intercooler pipe. looks fully standard though, cant pick it other than the large intake pipe.
hey guys
cheers guys
andrew
well im swaying more to the gcg as there is minimal work and expense to install is and running it
and if this turbo can give me 330-350 rwhp ill be happy :D
cheers
andrew
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
