Vt Ss Commodore 5.7l Auto
VT SS II Commodore 06/2000 5.7L Auto White 120,000km
Airconditioned
Tinted Windows
2.1T Heavy Duty Tow Bar Hayman Reese
Electric Brakes
Roof Racks
Kenwood, JBL, Sony Sound System with Stinger cables (Installed by FHRX Studios, CD of install available)
Serviced Regularly Log Books
Lady Owner
Many Extras including 2x New Tyres, 8mths Rego, New Alternator, Power Steering Pump, Battery and more.
Location Hills District, Sydney.
$15,000
Andrew 0407 669166
post-5777-1150115002.jpgpost-5777-1150115083.jpgpost-5777-1150115118.jpgpost-5777-1150115180.jpg
Edited by wolverine
hi ownage, unfortunately i am not looking for a trade (although i have had very good offers on some very nicely presented cars)
i am in the same boat as most other guys here i realise i can't get much of a premium for the extras on the car but i would like to get a fair price and find a good home for the commodore unfortunately fitting a dog and baby wolv in the SS is a bit tough.
the stagea is just about finished and ready for the road so i am ready to sell the commodore.
  • 3 weeks later...
  • 1 month later...
  • 5 months later...
still for sale.
the big bugger is great buying providing you:
a. don't expect me to give it away
b. tell me you are on your way (and actually show up)
c. you are not looking for a swap (although i know some swaps have been for very tidy cars)
d. looking for a family car with all the fruit
c'mon SAU
Edited by wolverine
 Share
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
    • That's the pink sticker type, you haven't said what car so no idea if it's correct, 25de or det is the same in the same model.
