dezz Posted June 12, 2006 Share Posted June 12, 2006 Ok guys here's the story Was at the SAU drag day on may6th...R33 GTS-T with full 3"...no other mods. Had the first run, no problems. On the second run, as I was approaching the end of the 400m, I was in third, and needed to select 4th before hitting the limiter...So i did. The stick sort of grinded and didnt come out of third, so i just thought i'd missed it, and backed off. As i was trying to slow down to take the exit, i tried to gear down into 2nd, and the same thing happened.... realising something was wrong and it was stuck in 3rd, I just drove it back to the parking area like that. A few of the SAU guys tried to get it into neutral, but it would not budge. anyway, towed it home and took it to a certain workshop on the monday. They took the box out and gave it to the "gearbox specialist" they use..."its worse than first thought" was what i got a few days later...apparently selector fork (which I was told by the SAU guys) and the "clutch hub assembly" between 3rd and 4th. Not knowing anythin about gearboxes, im just quoting what ive been told. anyway, fast forward 5 weeks, and basically nothing has been done. The reasons ive been given are the NISSAN themselves dont know what part it is, even having seeen the part in person etc. 5 weeks without the car, and no real progress being made, I should've posted this thread a long time ago, but my lack of knowledge on what part im asking about is what stopped me. I'm calling on anyone thats had this problem before (stuck in 3rd) and also anyone that knows their stuff as far as the R33 boxes go. I REALLY need the car back ASAP! Thanks in advance for any help, and sorry about the long post. But it should answer most questions straight up Cheers Dezz Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/ Share on other sites More sharing options...
kjb_r33 Posted June 12, 2006 Share Posted June 12, 2006 (edited) Ok guys here's the storyWas at the SAU drag day on may6th...R33 GTS-T with full 3"...no other mods. Had the first run, no problems. On the second run, as I was approaching the end of the 400m, I was in third, and needed to select 4th before hitting the limiter...So i did. The stick sort of grinded and didnt come out of third, so i just thought i'd missed it, and backed off. As i was trying to slow down to take the exit, i tried to gear down into 2nd, and the same thing happened.... realising something was wrong and it was stuck in 3rd, I just drove it back to the parking area like that. A few of the SAU guys tried to get it into neutral, but it would not budge. anyway, towed it home and took it to a certain workshop on the monday. They took the box out and gave it to the "gearbox specialist" they use..."its worse than first thought" was what i got a few days later...apparently selector fork (which I was told by the SAU guys) and the "clutch hub assembly" between 3rd and 4th. Not knowing anythin about gearboxes, im just quoting what ive been told. anyway, fast forward 5 weeks, and basically nothing has been done. The reasons ive been given are the NISSAN themselves dont know what part it is, even having seeen the part in person etc. 5 weeks without the car, and no real progress being made, I should've posted this thread a long time ago, but my lack of knowledge on what part im asking about is what stopped me. I'm calling on anyone thats had this problem before (stuck in 3rd) and also anyone that knows their stuff as far as the R33 boxes go. I REALLY need the car back ASAP! Thanks in advance for any help, and sorry about the long post. But it should answer most questions straight up Cheers Dezz Synchro hub assembly is probably the more correct term. It consists of the sliding sleeve, Baulk rings, synchro hub (which is splined to the output shaft), key inserts and insert springs. I'll have a look for p/no's when i get home, if you send me your vin number. For it to lock into 3rd gear id say the baulk ring has collapsed and the sliding sleeve has jammed onto the distorted baulk ring/hub. Edited June 12, 2006 by kjb_r33 Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2250411 Share on other sites More sharing options...
dezz Posted June 13, 2006 Author Share Posted June 13, 2006 Synchro hub assembly is probably the more correct term. It consists of the sliding sleeve, Baulk rings, synchro hub (which is splined to the output shaft), key inserts and insert springs. I'll have a look for p/no's when i get home, if you send me your vin number. For it to lock into 3rd gear id say the baulk ring has collapsed and the sliding sleeve has jammed onto the distorted baulk ring/hub. thanks for that mate...there was mention of keys and springs or something like being broken or damaged ill PM you my VIN now, and hopefully you can help me out!!!!!!!!! Thanks Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2250769 Share on other sites More sharing options...
justin911 Posted June 13, 2006 Share Posted June 13, 2006 perhaps take it to someone qualified ??? Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2251748 Share on other sites More sharing options...
dezz Posted June 19, 2006 Author Share Posted June 19, 2006 someones just pointed out to me that on the fast diagram kjb_r33 provided me, it says "app date 95-01" now by 33 is a 1998 series 2...so is there a different diagram for mine in fast? the workshop is telling me that nissan australia says the part number in fast is incorrect, and doesnt match the part i need... in the pic, its the part highlighted in green, under the 4 other green part numbers...its 32608+B part number - 32609-70L20 im DESPERATE now and REALLY REALLY need this sorted out and fixed ASAP. if anyone has good contacts in nissan, and can help me out, id be VERY VERY grateful! Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2267538 Share on other sites More sharing options...
PHATR32 Posted June 19, 2006 Share Posted June 19, 2006 i done a quick search and foudn the same it seems that the boxes from 95 onwards are the same. steve Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2267702 Share on other sites More sharing options...
Yorik Posted June 21, 2006 Share Posted June 21, 2006 Northside Nissan in Perth have a few good guys for getting Import parts, try them. Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2274976 Share on other sites More sharing options...
BL01 Posted June 21, 2006 Share Posted June 21, 2006 Dezz, try ringing up Nissan Blackburn to see if they have any in stock. They mostly store import things in their warehouse. Tel: 98772755 Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2275811 Share on other sites More sharing options...
PHATR32 Posted June 22, 2006 Share Posted June 22, 2006 yes, northside definelty know skylines. steve Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2276358 Share on other sites More sharing options...
eMsta Posted June 22, 2006 Share Posted June 22, 2006 Why not try RE Customs - they know their imports Or LA Performance - apparently the guy there knows his skylines very well... Link to comment https://www.sau.com.au/forums/topic/122023-part-info-needed-asap/#findComment-2276393 Share on other sites More sharing options...
