From my experience and Scotsman who spoke to racepace a while ago. He said ben said some pfc's do it and some don't. It seems to happen when the pfc jumps out of or into closed loop - using the o2 sensor. You can stop it by turning the o2 sensors off I have been told.
Didn't read the whole thread though. Am I close??
Mine were always off. Still did it. Tried the old extra ground to the ignitor trick, no good......
Carton to the person that gets rid of this damn hiccup for good!
Edited by GTRsean
  • Replies 212
i have the same problem but i have splitfire coils, hks ignition amplifier new plugs and earth lead and still does it, i am however going to put a new ignition sub harness hope this fixes it.
a little more information if it helps anyone with ideas, i run PFC 8.04a and suffer from the hesitation. a little while back i swapped it out with a mate running the exact same version, ran it for a period of maybe 3 - 4 weeks without a hitch. swapped back and the problem came back with it. so it was looking like it was only specific units, however recently his has started getting the problem after a long period of hassel free driving... as mine was second hand when i first received it and his only played up after a while, could it be somethin that comes with age? something breaking down?? has anyone had the problem with a new from the box PFC?
i'd be interested in the pin connector (blue thing) and the state of it
is your securely fastened and neat or is the wiring shabby and kinked etc?
it could be something as simple as the pins for the ign for each cylinder is a little weak/finicky
and when users remove the stock ecu and fit the PFC its enough movement to make it not contact properly
its a long shot , but would explain how your mate now has the issue you mentioned - only after removing ECU and plugged in a new one
so it could be the connector on the car side (blue plug) or the socket on the BNR32 PFC's
Yeah i got this prob too, does it once every couple of weeks...sucks to do it every 15 mins! farrrk
put in splitfires STILL DID IT
changed the ignitor STILL DID IT
changed the cas STILL DID IT
added earth wires STILL DID IT
I got over it...seems too hard.
Any other model car do it? Like 33 GTSt etc..
yes does it without hand controller, i try leave my controller unplugged so stupid passengers dont go "ohhh can i play the playstation" and pick it up and end up with god knows what. as for my wiring, you could say its a bit of a mess its an accomplishment in itself to unplug the thing.
Ive just removed my twin turbos and replaced with large single so its going for a tune next week, ill ask matt spri at PITS if he has any ideas that man knows PFC's like the back of his hand.
Edited by ow_damnit
Tried regrounding the ignitor pack and no sucess, has anyone tried to contact apexi in japan and ask for a fix. Maybe it maybe a companent in the ecu which is not soldered in, software????? This is very annoying
Anyone tried running datalogit with sucess maybe a solution if someone does.
Edited by cefiro
Mine is doing this too - such a pain. I think Paul you might be on to something with the pins - going to get in and push on each of the IGN wires hope it makes a different.
Some days it wont do it at all, other days it will do it every 15 minutes.
  • 4 weeks later...
  • 3 weeks later...
I had never had this problem with my BNR32. I have a completely new ignition system, all looms, earthing kit, HKS DLI twin power, Splitfires. But I had my engine rebuilt, and since getting it back, I get this damned hiccup/stumble at around 2500rpm at light throttle. It usually misfires once, but sometimes twice.
I question whether its an ignition problem because I have wideband logs. If it were an ignition misfire, the AFR would spike rich, and ignition cuts are smooth anyways. This hiccup is a slight jolt, and if you've ever hit a fuel cut limiter, you'll know just how bad a fuel-cut jolt can be!! Anyways, when it misfires, the AFR spikes LEAN. Meaning, the ECU is cutting an injector or two...implying a software bug.
But the thing is, it hadn't done it before. Only after getting rebuilt, and my earthing wires did get moved around to different locations. I'll try to put them back where I had them, see if that makes any difference.
Add me to the list!!!......
i have a 95 r33 gtr, with power fc, and have the occasional hiccup with the car at light loads, generally ~2500-3500rpm....
Im so used to it now it doesnt bother me (so long as it doesnt damage its all good)......i have it happen once every few days....
both my 32 GTRs have done it. one didn't do it for years, maybe 2 or 3 years with the PFC fitted. then out of the blue it started. not very often though, and it's not very bad, just a minor anoyance. the other GTR had big $ engine, turbos, cams, AFMS, the full monty and it did it too. the PFC in the first one I bought used (but 8.04a) the other one I bought brand new also 8.04a.
I must confess I've done bugger all to fix it. but the first car I mentioned is about to get new AFMs, new injectors and brand new engine, and new coil pack harness and new grounding kit so hopefully it disapears.
Sounds like ignition problem. When tehre is a missfire, the AFR goes lean, as an O2 sensor measure oxygen, which there is plenty when there is no spark.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
