  On 01/02/2013 at 4:04 PM, Don Dada said:
You cannot always see a cold solder joint....might as well do it while its open, and seal it back well to avoid moisture getting in
x2 on that.
It may even look good.
but take a magnifier glass to it and you may see a what looks like a crack at solders edge,
again this is a poor joint and needs fixing.
  • 2 months later...
  • Replies 212
Thread Re-birth 21/4/2013 and still no official fix?
Car R32 GTR 1994 JULY build...
Mine only happens maybe once every 200-500km or 3-6 days Very random and unpredictable. It happens rarely which is why I have not been so keen finding this problem specially when I see so many people having it and not one person finding an official solution.
Guys my aim is to one day fix this issue, whether it be changing to a D-metro or a whole new computer all together. Is there anything which is better then the PFC for the GTR other then the D-metro?
I am slowly changing every nut and bolt in this beast But ofcourse my aim is to get rid of the bugs 1st if possible. Car is not stock , -5s , Cams, AFM, Injectors, Fuel P, Coil pack-SF's, Gearbox etc... All internals are still stock and I am running at a Safe/healthy 330awkw.
I really want to get to the bottom of this now.... Im in sydney is there anyone wanting to chat about this seriously?
it's not d-metro its d-jetro. the stock pfc users airflow meters and it is l-jetro and the map sensor version is d-jetro
its likely the d-jetro has the same issue as its just map sensors instead of airflow meters
D-metro is the most manicured ecu of the PFC line up...
Where does the missfire occur? What plug gap? How old are the O2 sensors?
  • 1 month later...
Not sure where the miss fire occurs? What do you mean Have you looked through this thread its the same weird thing some people have with PFC, its like a microsecond surge of NO POWER. Hiccup..etc...... o2 sensors are not old at all, this is not a daily.. I basically changed all the wear and tear bits at 90k now its 96... dOne the 100km service and I am pretty sure the 02 sensors were changed whilst getting tuned either way I have not anyone talk about old 02 sensors in this thread. How ever my alternator is Very week its on 11.5V whilst driving I wonder if this may be the reason... Then you would think it should keep happening constantly not ev
every 200-600kms right??
neway
I have a RH9 130A Hyper alternator coming in the next couple days.
Has anybody solved the problem??
LOL funny you should say that, Its been weak since I can remember I bought it in 2006 first buyer in AUS Build Date July/1994 68k Speedo. It used to sit on about 12.6-12.8v then slowly dropped .So even then it was weak, I was told it should be between 13-14v while driving. Anyway now it varies between 11-12v Not very good the other day the volts kept going up and down 10.6 -11.5 And then all of a sudden my power steering cut off until I stopped the car waited a bit then drove again. Went back to normal and voltage stayed around 11.5 but this is when I went online and ordered a hyper alternator.
Anyways So the mysterious missfire any one manage to get rid of theirs completely with the PFC?
lol d metro
mine does this random surge, new plugs, new z32's, new injectors, new splitfires, only does it while cruising like most other ppl
  • 3 years later...
Sorry for bringing a old thread up
But i have pfc with ver. 8.04a and also have this mysterious  missfire too. I have seem Apexi sell news version too . It ver.9.00 do still have the bug ?? Someone with it can confirm ?
Last question for who have switched to Ls coil. The problem go aways or still there?
Edited by NoLimit0596
Error
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
