You cannot always see a cold solder joint....might as well do it while its open, and seal it back well to avoid moisture getting in
x2 on that.
It may even look good.
but take a magnifier glass to it and you may see a what looks like a crack at solders edge,
again this is a poor joint and needs fixing.
  • 2 months later...
  • Replies 212
Thread Re-birth 21/4/2013 and still no official fix?
Car R32 GTR 1994 JULY build...
Mine only happens maybe once every 200-500km or 3-6 days Very random and unpredictable. It happens rarely which is why I have not been so keen finding this problem specially when I see so many people having it and not one person finding an official solution.
Guys my aim is to one day fix this issue, whether it be changing to a D-metro or a whole new computer all together. Is there anything which is better then the PFC for the GTR other then the D-metro?
I am slowly changing every nut and bolt in this beast But ofcourse my aim is to get rid of the bugs 1st if possible. Car is not stock , -5s , Cams, AFM, Injectors, Fuel P, Coil pack-SF's, Gearbox etc... All internals are still stock and I am running at a Safe/healthy 330awkw.
I really want to get to the bottom of this now.... Im in sydney is there anyone wanting to chat about this seriously?
it's not d-metro its d-jetro. the stock pfc users airflow meters and it is l-jetro and the map sensor version is d-jetro
its likely the d-jetro has the same issue as its just map sensors instead of airflow meters
D-metro is the most manicured ecu of the PFC line up...
Where does the missfire occur? What plug gap? How old are the O2 sensors?
  • 1 month later...
Not sure where the miss fire occurs? What do you mean Have you looked through this thread its the same weird thing some people have with PFC, its like a microsecond surge of NO POWER. Hiccup..etc...... o2 sensors are not old at all, this is not a daily.. I basically changed all the wear and tear bits at 90k now its 96... dOne the 100km service and I am pretty sure the 02 sensors were changed whilst getting tuned either way I have not anyone talk about old 02 sensors in this thread. How ever my alternator is Very week its on 11.5V whilst driving I wonder if this may be the reason... Then you would think it should keep happening constantly not ev
every 200-600kms right??
neway
I have a RH9 130A Hyper alternator coming in the next couple days.
Has anybody solved the problem??
LOL funny you should say that, Its been weak since I can remember I bought it in 2006 first buyer in AUS Build Date July/1994 68k Speedo. It used to sit on about 12.6-12.8v then slowly dropped .So even then it was weak, I was told it should be between 13-14v while driving. Anyway now it varies between 11-12v Not very good the other day the volts kept going up and down 10.6 -11.5 And then all of a sudden my power steering cut off until I stopped the car waited a bit then drove again. Went back to normal and voltage stayed around 11.5 but this is when I went online and ordered a hyper alternator.
Anyways So the mysterious missfire any one manage to get rid of theirs completely with the PFC?
lol d metro
mine does this random surge, new plugs, new z32's, new injectors, new splitfires, only does it while cruising like most other ppl
  • 3 years later...
Sorry for bringing a old thread up
But i have pfc with ver. 8.04a and also have this mysterious  missfire too. I have seem Apexi sell news version too . It ver.9.00 do still have the bug ?? Someone with it can confirm ?
Last question for who have switched to Ls coil. The problem go aways or still there?
Edited by NoLimit0596
Error
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
