well you fark knuckles! I never had this problem before. but the now it's occaisoinaly started happening. I blame you guys and your thread!
going to try some earthing etc. see how I go.
  • Replies 212
it's actually a computer virus I have written for the PFC - that is spread by reading this tread :P
you bastood.
some more info if it helps.
I'm running a BCNR33 RB26 PFC in my BNR32 GTR. It's firmware is version 8.04a (latest firmware) and is not reflashed. It was tuned by PC (using datalogit from memory). running with O2 feedback on (and at least 1 faulty sensor, the other one i'm not 100% if faulty or not).
tune is excellent. car is currently making 270kw atw with 1 bar boost. also running splitfires coils, and NGK copper plugs (BCPR7ES gapped at 0.8mm).
you bastood.
I have my O2 sensors off - also have ~270atw with splitfires and copper plugs
same firmware
I pulled mine apart on sunday to have a look. Mine had a ground wire which was screwed onto the top of the transistor (ignitor pack thingy). the ground wire is connected to somewhere I cant really see as it was wrapped in a cable sheild with some other wires (but I believe its connected to the negative side of the battery. I just cleaned off the rust of the screw and the wire connector and since then i have had no missfires. Before this the missing happened at least once a day sometimes 2 or 3 times. But will have to see if it does it over a few more days.
i have had this problem too, ive located it to a faulty tps switch, it drops out and gives flat spots just on low throttle. very very intermittent.
btw 60 knock is regared as an "event" 20-40 is acceptable i believe. ive never seen more than 40 and only on decel, never on acceleration.
so - a new tps ?
Its like a curse., F%$K Y&^...noticed it the last couple of days on low RPM cruising along.
Why did I look for it.?????...could have had the stereo vibrating the car and would have never noticed.
My cover is off ,,,I have a PFC, Splitfire coils and the ignitor pack is not attached to anything.
Some-one please post up a quick fix with some wiring info......I have nowhere to fix it to.
If you don't I will put a Hex on all your cars :ninja::dry::D
OK Then....here is a quick mod. I have completed today to see if it stops the missing.
One fixed point........the other a cable tieing up 2 other points and fixing to another point.
The wire is thick on the second....and no movement at all.
So far tonight had no missing.......infact car is running smoother. :P
If it happens again...I will replace tps.
  • 2 months later...
Did a simular thing to my R32 GTR recently. Ran a ground directly from battery negative to transistor module. From transistor module to both rear and front coil pack mounting bolts. Also cleaned paint off mounting pads for transistor module. To date, no missfire. Blooody unreal, all sorted. :sorcerer:
Had the same problem with mine. Checked the earth on both the ignitor and the coil packs and found both had loose connectors. Soldered the connector to the wires and misfire has gone. Also problem only occurred once i took the cam cover off.
  • 3 weeks later...
I get this misfire once a month on average. It feels ike the engine just skips a beat, I thought the timing belt was slipping the first time I felt it :)
My recent re-tune brought my knock level right down. At start up it jumps up to 80, but once I reset it and drive, even with a cold engine I rarely see knock over 18 now.
  • 2 months later...
you bastood.
HI THERE. MY R32 GTR HAS THIS DAM APEXI MISFIRE ALSO. WHAT I HAVE NOTICED AFTER HAVING THREE SETS OF O2 SENSORS INSTALED THAT ONE OF THEM WILL ALWAYS SHOW THAT IT READING JUST ABOUT ZERO IF NOT ZERO VOLTS WHEN THE CAR IS WARM OR HOT, FROM DEAD COLD START YOUR CAR AND HAVE A LOOK AT YOUR HAND CONTROLER AND KEEP AN EYE ON THE O2 SENSOR VOLTAGE WITH BOTH OF THEM TURNED ON AND SEE IF THE NUMBER TWO O2 SENSOR STARTS TO LOOSE VOLTAGE AS THE CAR WARMS UP. WITH MINE IT IS ALWAYS THE NUMBER TWO O2 SENSOR ON THE HAND CONTROLER. THE NUMBER TWO O2 SENSOR ITSELF IS IN THE POSITION CLOSEST TO THE FRONT OF THE CAR.
I HAVE ALSO NOTICED THAT THE MISFIRE IS THERE WITH THE O2"S TURNED ON OR OFF. I HAVE HAD MY CAR TUNED BY 4 DIFFERENT TUNERS TO TRY TO GET RID OF THIS MISFIRE AND NO LUCK. CAR RUNS A NICE POWER OF 384.4 HP AT THE WHEELS.SOME SAY THAT THE APEXI IS THE WAY TO GO BUT FOR MOST OF US WITH R32 GTR,S. ALL THE BEST
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
