Hey pplz.. I guess this is the fun part about owning a car i was sposed to be going for a roadworth cert. last friday but now shes playin up :D okay..saturday last weekend i put all new plugs in my R31, that afternoon it worked perfectly...(quieter..no smoke) then the next morning i started it up, it idled fine, let it warm up then lightly put my foot down and the revs dropped? to about 500Rpm and nearly stalled, then once it got past that stage and revved it to around 2000rpm it started unevenly revving (1500 - 2500)... so any help would be greatly appreciated, changing the plugs is all i have touched under the bonnet since it started playing up..i am trying to avoid a mechanic atm as they'll no doubt charge more than i paid for the car :)Brady.
Edited by BradyJ_R31
https://www.sau.com.au/forums/topic/122109-weird-misfiring-at-2000rpm-rb30/
Did you put the leads back on in the right order?
Have you re-checked that one of the leads hasn't come loose?
Did you buy the right plugs?
How did the old plugs look? (colour/condition)
Did you touch anything to do with the distributor?
You mentioned smoke prior to changing the plugs, what colour was the smoke?
Um the guy at supercheap auto picked out the plugs for me....they fit perfect and all but would surprise me if they are wrong, nah i checked all the leads and lead numbers, the old plugs had barely any soot on them but were very very old, i was going to try putting the old ones back on but i threw them all bar one : the smoke prior to the new plugs was like wispy blue smoke, evn after it had warmed up, i had a look in some other forums and some ppl said there AFM was gone....wats that lol...thnx brady
Everyone seems to jump to the AFM (Air Flow Meter) conclusion, but its rarely the cause.
If your car ran fine before you changed the plugs then there is really no reason to look at things like the AFM.
Start by looking at the plug leads - are they clean and tight fitting. Are they in the correct order?
Look at any inlet piping removed during the replacement - are any hoses loose or missing (some are under the inlet / plenum and can be hard to see).
Look at the electrical connectors - are any loose or disconnected?
Hope this helps! If not, let us know and we'll give you some other pointers!
Cheers,
J
Ahh ok, because i did have to take all the inlet piping off above the rocker cover, i did not know about too many hoses under the plenum lol, so i might have to check it out, how much (average) would all new spark plug leads cost? could be a wise investment, the old ones could be the cause aswell as they arent the best lookin ones ive seen :D
I have a set of standard leads on mine original from factory - still working perfectly.
Mate of mine had a set of after market 8mm leads on his GTS - ran like shit. Ended up putting my standard ones on the GTS...
Also, make sure your oil filler cap is tight and sealing properly. This will make a big difference if not right!
Geez i never realized how many things it could be lol but yeah this weekend i might just get in there and try it all out, maybe go back to supercheap and check the polug type, could it be anything fallin into a cylinder (dust,gunk) thats doing it? from when i took the plugs out,?..thanx a heap
Yeah it sstill starts 1st time everytime, and it idles fine (around1000rpm) but if you slightly put your foot down the revs will drop....then pick up again and at round 2000 it just fluctuates the revs, but nah i havent checked the gaps yet, thnx brady
make sure you have the right gap in the spark plugs as well this makes a big difference.
For 33's its 8mm's off head. Dont know about yours but should be similar
8mm thats a big gap!!! I think he means 0.8mm. And for a naturally aspired RB30 it should be about 1.1mm gap. Check that you didn't crack a plug when you installed them would be my advice.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
