this has really got me puzzled...
we went to start the car today after my rebuild when #1 wasnt firing. it wasnt showing compression and there seems to be no compression leak through the rings, or through the head..
my only option now is to run the car and hope the lifters bleed themselves properly as its up on ramps now. then get a leak down test.
if anyone has any idea what it could be PLEASE let me know.. we installed new rings, head gasket and got the head machined.
https://www.sau.com.au/forums/topic/122112-compression-problem-after-rebuild/
  • Replies 57
sounds a lot like a rooted/unbled lifter to me. if you're keen you could whip the cams out and pull the 4 lifters involved, clean them and put them back in. or just run it and hope they bleed themselves. it won't damage anything really if you do it the easy way.
i'll give that a go tomorrow mate. thanks for that.
You can borrow 4 spare lifters that i have from a spare head for a TEST if you like. As long as you promise to give them back when your finished (same ones) :P
pm me if you need em - only thing is they are in Newcastle but this could help - thought i would offer.
Did Duncan Foster assemble the cyl head or did you ?
If you did did you lupp the lifters out? If yes how did you store them ?
How is the compression on all the other cylinders? Have you had it checked?
Pull them back out and let them soak in tub of light engine oil overnight. might take half an hour to bleed up at 1500 rpm after instalation. i get this all the time when doing engines. dont stress to much.
just in a box.. i blew them out thoroughly before installing them though.
Are all the springs in? If you are going to clean the lifters you have to bleed them before instalation, if you are not going to clean them you put them in and oil can upright .
Is compression zero in number 1? Whats the compression on the other cylinders? Was is making a racket when you first started it? is it quiet now ?
So you pulled the valves out and relapped them , correct?
Did you bend a valve ? Did you put the valves back in the same spot as they were before? You have to tell us a lot more detail if you want a possible sollution .
You are not having much luck there Joe, is this number 3 rebuilt atempt?
By the way i dont think your problem is a lifter.
Edited by wrxhoon
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
