Thats why I had no idea what you were on about. I still have all the crap installed, but before I fixed it the steering rack solenoid was disconnected, same as removing the hicas module. The electrical signal going to the power steering modulation solenoid, the one on the steering rack, comes from the hicas module, without the module, you get no signal, so you get no solenoid actuation, which means you have permanently heavy steering.. Which you obviously like, but I don't.. Each to their own. Unless you have another way of powering the solenoid or swapping in a non assisted rack.
fim using a r33 rack and lines. however the hicas ecu would control the solenoids so if you earth the solenoid out it will stay open, however that may cause the solenoid to burn out over time.
depends on your setup mate, for most r32's you'd leave the ecu in.
  • 1 month later...
  • 4 weeks later...
I'm just trying to swap a single hicas tie rod (ball joint is shagged) so I can pass regency. To just replace one do I need to take the boots off both side and lock a shifter on one side so that it doesn't spin when I undo the other side?
Because I tried just undoing one side and it cracked but just keeps turning, it is however quite hard to turn (needs both arms) but it doesn't appear to be loosening off. Just want to know before I go out and buy a second shifter.
Cheers.
  • 4 years later...
How do you do this exactly? I'm not the best at electronic lingo yet. But is it as simple as jumpering two pins at the end of the connector that would have gone into my missing hicas ecu? Does anybody know the wire colors if thats the process<<<? Thanks for the help. Also sorry for bumping this old thread.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
