Thats kinda nice coz you can see the fuel pressure.... kinda
you wont need an FPR for 11psi+pod mate
I run 16psi (GCG) on stock ecu, pod, full split exhaust/highflow cat/catback and GTR FMIC. The only thing you need to look for is R&R which i occasionally hit and fuel isnt that great :D
hi what rwkw do you make is it a rb25 and what is a (GCG) is it a rb25. and i thinck it will be ok to get it now for other mods later like a e-manage ULTIMATE. and what is R&R.
Edited by RB SANDY
Have a look at the Nismo adjustable FPR (~$140 from Nengun) it bolts directly onto the fuel rail, so it saves buying a fuel rail fitting, hoses and clamps.
As used by Sydneykid and Mines, so it can’t be that bad
:D cheers :D
SK, I have just ordered a nismo fuel pump and regulator "as pictured" along with a set of nismo 600cc injectors to strengten my fuel system and be in a position to upgrade to r34n1 turbos or other low mounts GTSS maybe for track and targa.. I have a standard R33 GTR except for apexi powerfc and boost controller which made 283rwkw post an exhaust change. My question is after fitting the regulator do you maintain the standard pressure as it now "guaranteed" or should you increase it and if so to what pressure.
Edited by sparkmanv11
RWKW...naa mate, I make AWKW :P.
Yeh, RB25 in a Stagea. Made 160awkw with the coilpacks breaking up above 5000rpm. Peak power is still climbing at like, 7000 rpm too.
GCG is the turbo, a highflowed standard turbo. www.gcg.com.au
R&R is rich and retard, the ecu retards ign timing and richens up the mixture. Feels like a bit fat bang, then it slowly builds up again and off you go. Its pretty annoying...
BTW, that was on a hub dyno... the best kind of dyno
:P cheers ;)
Hey guys, just a quick and possibly stupid question :)
Do the RB20s have a FPR as standard? If so, is it that little object that sits in front of the inlet manifold that plumbs into the fuel rail? And if it is, why the hell does it have a little rubber hose that connects the side of it to the inlet manifold? I don't understand why an FPR would need to read or use inlet pressure??? But that's because I'm an idiot :( I see that one SK posted also has a little nipple that looks like the same position as the one on what I think is my standard FPR.
Please help me out of this confusion :)
Ben.
Anyway, this thread is about fuel regulators. I wouldn't trust a cheap one. I tried a Malpassi but wasn't happy with it - noisy and inconsistant pressure.
When it comes down to it, it's a very important piece of gear and it could cost a shitload if something goes wrong.
I'm not one of these 'give me brand names or give me death' kind of people but there are some things I wouldn't trust to the cheap end of the market.
exactly why i'm going to a Nismo FPR... no machined aluminium, no anodizing, just something that should do it's job and is virtually Nissan sanctioned... while cheap to boot!
