it has rather agricultural sound turning corners and a rather loud clunking sound we open it up and replaced some shims (aparently i wasnt involved i should say they) and it stoped for a while what do the best way of explaining the dif is that its either locked or its not but its not a fully locked diff will that red line stuff help, any help will be much appreciated
https://www.sau.com.au/forums/topic/12219-steel-clutch-diff-what-do-i-do/
Sounds like a detroit locker. They are supposed to be very strong but if your looking for finesse....forget it They lock up with a clunk when you go round a corner and unlock when you exit, very agricultural.... I wouldn't have one in a road car.
What's wrong with the Skyline LSD ??
Originally posted by crooser
take a couple of deep breathes and try again... this time in english :D
Nominee for post-without-punctuation award? Looks like he knew something was wrong near the end though, where he threw in a comma instead of a full stop. Santa, my only wish for Christmas is that people would finish primary school level English before buying a Skyline.
About the diff. If you haven't replaced oil yet, then definanlty give Redline a go. I know several people with noisy diffs (none of them Nissan), that weren't so noisey after diff oil was replaced for something more slippery. Probably won't fix the problem but it'll make it a lot less noticable.
Is it a standard Nissan viscous diff?
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
