  • Replies 79
Love the front bar, I'm thinking of getting some side skirts and a rear wing for mine so if you don't want the wing, I'll take it :D Honestly I'd put the wing back on, I have seen some 34's without wings and they look pretty damn nice, but I dunno... either way I like.
Is your colour actually black or is it a dark blue like mine? I can't actually tell!
As for lowering it, I'm affraid to do it to mine, the cost versus the benefits don't make it seem like it's a good idea IMO. I drive in some parking lots and side streets with some very bad speed humps so it would worry me doing it, even on 18's.
Anyway I love the front bar, looks shit hot :D
so what's the deal with a real R34 GTR then? :D
Not sure, maybe the front bar sits lower on your car?
Or maybe the GTR has a bigger diam wheel/tyre - whats the stock tyre size on a GTT and a GTR and i can work it out for you....
Or ask Troy he'd probably know...
OzGTR02 (i think thats his sig) in Sydney has a sweet R34 GTR with all the front lips. It is the sme as yours, in that the front is crazy low even if the car itself isnt.
Paul has awesoem Weds with big dish, but last time i saw his car at Eastern he still has std suspension under it trying to work out how in the hell could he lower the thing without turning it into a street sweeper
edit...actually just found a recent photo of his car and i guess you can see what beign so low has done to it in the months since i saw his car.
while the bar looks like an exact replica or an R34 GTR bar, there may be differences in mounting points etc, and like I said the bonnet of a GTR sits higher. So probably slight differences in the height of your bar vs a GTR bar - any it may be slightly deeper than a stocker
The front tip which normally tips down has been cut, folded over and made to be like an R34 GTR bonnet.
The whole section would have been sanded back etc.
The black is undercoat/sealant to protect the area before it gets sprayed.
that's cos the car is smiling troy, shit... i'd be too if i'd look like that :thumbsup: - give a big cheesy one to the guy with the camera :ermm:
pete's right, just a protective layer before i spray it... i toyed with the idea of having the car done satin black, so a little matte, but a little shiny too... i think i ended up thinking it was a silly idea.
stock R34 GTT tyre/wheel combo's are 17", 225/45 i think?
do i have to keep the same diameter? i'm guessing 18" with 40 tryes would still be bigger than 17" 45?
yeah, it's $1200 i think, without the lower lip parts (2 sections, another couple hunge) and then you gotta spray it... will be a little disappointing when there are dodge fibreglass copies of this floating around... oh well, at least i can say i had the first one :wub: or an original one...
so according to the calulator i shouldn't change rims where the difference is greater than 3%..
must admit, didn't quite follow the site...
said 265/40/R18's were 5.3%, didn't like it...
what exactly does the site tell me?
that doesnt matter
it just affects your speedo, nothing else
its telling you the rolling diameter of the wheels
dan -
i would think that you'll want to go to 235/40/18 and 265/35/18s
same as R33GTSt
to maintain the same (similar) rolling diameter
That is correct. I have the same on my 34
Chinny - I've seen your car, my rims would fit under it easy. The only issue I saw with your bar is the height of it, dropping the car would be a b|tch.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
