lean in, or out. the correction affects where it lands on the load axis as determined by afm ramp value * afm voltage then correction applied to plot it on the load axis.
so 80% correction means that if the airflow calc gives it 14000 which ends up being load point 14 then it will end up load point say 12 as the 80% correction will decrease it's load point
https://www.sau.com.au/forums/topic/122208-power-fc/#findComment-2255745
thanks mate! :D
https://www.sau.com.au/forums/topic/122208-power-fc/#findComment-2256582
